Best cam w/ stock LS-1 heads??
Full bolt on A4 car... (2000 C5)
Vararam, LS6 intake, LG headers, no cats, Vigilante 3200, FLP Level IV.
Car is 95% track, the other 5% is driving to & from the track, but I want to retain full streetability, so no roll bar, no big lobe...
Don't want to go too radical, as another .2-.3 is about as much as I'd like to lose in ET..
This is what I'm thinking, would like opinions & sugestions...
TR 224/224 @ 114 .563/.563
or
Futral FM-F2-114 224"/224" .588"/.588" 114LSA
Thanks for the help....
I would be using stock rockers, but upgrading to Comp 918 springs, chrome molly pushrods, titanium retainers, & also getting the Meizre electric water pump. Do not want to go with ASP or other pulley...
or
Not really considering a 112 LSA..
Looking for a pretty smooth/ stock like idle....
I'm kinda open as far as the FM2 or the FM4
Not quite clear what the difference is between the 226/226 .575
vs the 224/224 .588 both being on the 114 LSA..
Care to explain?
Care to explain?
You do know that not all 112 LSA cams are radical, right? Look at this vid, it's my car with the F11 (228/230 .575/.595 112LSA). Almost idles stock, a lot of people complain becuase its not lumpy enough, but makes real nice power.
please right click and save:
http://www.lsuxblake.com/vidcam.avi
Can't go wrong with any cam Futral cam.....
If I was you I would go a little bigger... you can even go a cam as big as mine and not lose a bit of drivability as long as you get the correct tune.
Care to explain?
Care to explain?
226 has a -2 * overlap
224 has a -4 * overlap
so the 224 has a better chance to pass sniffer with a proper lean tune.
the more negative degree of overlap the better chance to pass.
Yeah, perhaps I worded it wrong. Obviously the FM2 will have a better chance of passing. But... I think the FM4 will pass as well. I think the others FM5 thru FM14 will be very difficult to pass, despite the tune.
From what I've read, the the FM4 will net me a few more ponies to the rear wheels (more than the FM2).
If so where in the rpms?? Is it peak? Under the curve?
First check you local emission laws and base your judgement on that. Not Hear say, but from the Lion's mouth.
Not concerned with emissions.
I'm exempt... Car runs under 5,000 miles a year..
I am more concerned at having a smooth idle, & not losing more then .2-.3 in ET, because I do not want to put in a rollbar.
In 55 degrees I run 11.75-11.78.
I can go down to 11.50 without a bar...
So a cam that could net me .2-.3 in ET is what I'm looking for, but want it to idle as stock...
MTI Stealth II here, 224/220, .581/.581 116+0
Really idle like stock but with a nervous rate. Also in the same power range as the TR224. With that cam , you can drive more than 5K a year, it will pass sniff, visual, you name it. And still rival bigger cams on top.
