Are 5 pinion planetaries necessary?
I'm collecting parts for my transmission build and I was wondering if I really need the 5 pinion planetaries. Has anybody ever broke the stock 4 pinion set up? The tranny will have to hold about 550-600rwhp.
Thanks,
Andrew
Thanks,
Andrew
plaets
Originally Posted by Tom's_SS
Ive seen broken 4 pinions. its worth the $$$ to get the 5 pinion. the front one is for your overdrive the rear for the other gears, the rear one i would get for sure.
Tom
Tom
So since this is a budget build. If I where to do one planetary it should be the rear? Also, is everybody using an aftermarket 5 pinion or is it just a stock 4L65 piece?
