What sponsor sells fitting to work w/ factory line
Originally Posted by Brian2001SS
I have a set of alum. fuel rails with AN fittings, but need to know how to adapt to the factory fuel line. Does a sponsor sell a fitting just for this?
Thanks
Thanks
Originally Posted by smokeum99ta
let me guess? you have got the speed inc fuel rails. anyway there is a hard tube adapter part #799-639200 or #799-639210 in jegs.thats 3/8 pipe to 6an male or female.hopefully you dont have 8an lines if so youll need a adapter for 6an-8an.Ive been looking for the 3/8 pipe - 8an but havent had any luck.hope thats what you wanted .
Originally Posted by Nasty N8
I have fittings in stock here My kits come with a fitting.
Nate
Nate
I aint trying to highjack but did you mean a 3/8pipe to 8an male/female. or that you have the rest of an fitting that I mentioned.
More or less, the fittings needed to attach a braided fuel line to the factory line with out cutting, flaring, and other modifications. I hope this helps understand where I am at. Thanks
that adapter doesnt need to be cut or flared its a simple ring that gos on the pipe that gets clamped to it.
