Stock pushrods and LS6 cam
Just wanted to see how many of you are running stock pushrods with an LS6 cam. I know you are supposed to run a longer pushrod, but I know of a few people that are still running stock pushrods.
Originally Posted by snakeoiler
The 02+ LS6 cam has a smaller base circle, why wouldn't you want to use a longer push rod in order to keep the geometry correct?
the difference is .035. If you install 7.40 (aftermarket stock) the diff will be .015.
If you use stock LS1 7.38, the diff will be ~.035
Ideally 7.420 should be your p-rod length.
depends on the size of the cam. I kept stock ones with my FM11. I've bounced the limiter a couple of times on accident no probs yet. I think it's if the cam is over .600 lift you want hardened ones. Might try a search for that one.
[QUOTE=ULTIMATEORANGESS]ive been running my stock PRs for years with this cam.[/QUOTE
I agree! stock pushrods do get the job done,but if a guy ever wanted to upgrade,hardened pushrods are great.
