Stage 3 Ported LS6 Heads w/ TR224 a bad idea?
Old 01-24-2005, 06:17 PM
Ferocity02's Avatar
Exclamation Stage 3 Ported LS6 Heads w/ TR224 a bad idea?
I am looking at getting some heads and have found a pretty good deal on some Stage III ported and polished LS6 heads. They have 2.080 intake and 1.60 exhaust with Crane dual valve springs and a 72cc chamber.
I am thinking that these heads are too big for my puni cam. The fact that the chambers are 72cc is bad enough. Can a head this big actually hurt performance. I think its more for a blower application than a N/A one. Thanks.
Old 01-24-2005, 06:22 PM
jrp
SN95 Director
jrp's Avatar
you'll need to mill them .030 just to get them back to stock compression. what are the port volumes on the heads and what bore are they setup for?
Old 01-24-2005, 06:25 PM
Ferocity02's Avatar
They are stock bore and I don't know what the port volume is
Old 01-24-2005, 06:33 PM
slow trap's Avatar
i've been wondering about power also.i'm sure bottom end will suffer but was wanting to see a comparison between s2 and s3 heads with a small cam and larger cam also.with that big of a intake valve p/v clearance may be an issue with a healthy cam.
Old 01-24-2005, 06:36 PM
Suspended Sponsor Account
ForceFed HP's Avatar
are they true LS6 heads? casting 243? cause a true LS6 heads with a 72cc chamber is probably not setup for stock bore and a 2.08 valve in a stock bore is shrouded like mad.
Old 01-24-2005, 09:31 PM
Ferocity02's Avatar
I think they are true LS6 heads, they came of a Z06 I believe...
So the notion that I am getting is that stage III heads are more for a big bore or stroker motor, or FI? Is this right?
Old 01-24-2005, 10:00 PM
dug
dug's Avatar
Youre gonna want a cam with more lift when running ported heads.
Old 01-25-2005, 02:04 AM
goober35's Avatar
If the are PP head they are 317 6.0 heads. I have never seen a 72cc ture 243 ls6 head. I have a 66CC chamber ls6 243 head and that is about as big as i have seen. I would think those heads are flared out for a bigger bore than a 3.898 or what ever stock is. I think that 2.08 intake is going to hurt your volosity so you will be down on some power with that and the 72cc chambers are not going to help eather. I would look for a2.02 intake at the biggest with a N/A 5.7 unless you want to runs a monster cam.
Old 01-25-2005, 04:02 AM
while there is not real standard for stages on cylinder heads(what one shop calls a stage 1 some call a stage 2) the head you are refering to sounds like what I would call a stage 3 and for us a stage 3 is suited towards 4" bores or larger.
