Best prices on 427-438 ci rotating assembles?
Restricted User
If you look around you can piece the parts list and pricing together:
Resleeved block $3,000
4" Eagle Crank $1,000
6.125" Eagle rods $600
6.125" Lunati rods $900
Mahle Piston/ring/pin combo $550
Bearings Main/Rod/Cam $200
That should pretty much do you there. Of course, you can go with the Lunati, Callies crank, or whomever, and rods and pistons too. But thats the basics there. Add in FelPro Head gaskets in 4.125" bore $80, or Cometics for $160. These are rough prices though. Swapping in the 4.125" bore and 4" stroke makes 427/428 with a slightly oversquare build and 1.53~ Rod Ratio (just under desired). Same combo I have been looking at, time to pick pieces up here and there. Then figure in unshrouded heads/port and chamber work. Hope this helps.
Charlie
Charlie
