th400-forward vs reverse valve body
Old 01-25-2005, 07:30 PM
97 white's Avatar
Default th400-forward vs reverse valve body
Which one is better suited for a street/drag car? Is one better for high power than the other? I know the reverse has no engine braking, so what happens if i let of the gas just coast like in neutral, what about downshifting ive been told you shouldnt unless stopped?
Thanks for the help
Chuck
Old 01-25-2005, 08:59 PM
98sspullin'em's Avatar
i want to know also because were i live there is a crapload of light and of course the turn green when you slow down to like 10 - 15 mph... and also want to know about the coasting thing, becuase my wife always goes a little to fast then lets off then hits the gas then lets off all the time, almost makes me sea sick lol... thanks
Old 01-25-2005, 09:51 PM
jxaxsxoxn's Avatar
If you go over say 35-40, coast and downshift into first knowing you're going to end up in first when you stop then you run the risk of over running the direct drum (which would normally be stopped by the front band) and this will sling oil off the sprag or roller clutch and it could fail due to lack of oil.
You can downshift, coast forever in third, etc. But don't make a habit of running fast and downshifting into first or second and coasting to a stop.
Old 01-25-2005, 09:57 PM
john kilgore's Avatar
Default vb's
there are reverse vb's with compression braking.
Old 01-26-2005, 07:20 AM
97 white's Avatar
Who sells vb with compression braking and would this be better for a street/strip car? Could i downshift and coast with this set up? Can i still have a transbrake?
Thanks
Old 01-26-2005, 09:38 AM
MeanWS6's Avatar
what about when you are crusing at say 30-40 in third, then start to slow down to say 10-15mph, do you downshift to second or leave it in third?
Old 01-26-2005, 03:30 PM
BLK02WS6's Avatar
Since my car is mainly a racecar these days, I went with a rev vb cause I don't want any chance of missing 3rd on the 2-3 shift and going into N! On the jug, that would be a very bad thing to do. I've seen even the best of shifters have plates fail or allow a missed shift - I'll live with the downsides on the street for the security on the track.
Old 01-26-2005, 10:52 PM
The Bull
DERTY's Avatar
Rossler sells a TH400 that has the 2nd gear drum banded to let it hook up like this. You can downshift just fine with it like this. In fact, you can be going 55 in 3rd, downshift and rocket away. It would sort of look something like this if you did downshift like that.
http://www.stenodracing.com/videos/Derty_Highway2.wmv
That's all motor versus a complete stock car with a Incon TT kit (around 600+ HP/TQ and 3800 pounds).
A gated shifter will also make a reverse manual very nice. I like mine a lot.
Old 01-27-2005, 08:36 AM
badass 2002 z28's Avatar
Important thing to know...If you want a transbrake you HAVE to get a reverse manual vb.
Old 01-27-2005, 10:07 AM
Default braking
Thanks
compression braking means the 400 retains the bands used for down shifting. in fact that is why a 400 is called "dual range". one path for power and the other for compression braking. l have such vb's
Old 01-27-2005, 10:39 AM
97 white's Avatar
Is there any reason one would not want to have compression braking in 1st and 2nd?
Old 01-27-2005, 06:28 PM
jxaxsxoxn's Avatar
To get to neutral without it down shifting like a stock trans where the car would slow down and the rpm would go up when it went through second and first. Thats on a reverse pattern.
Thats what I think anyway.
Quick Reply: th400-forward vs reverse valve body
