Cometic thickness questions....
Old 01-26-2005, 11:21 AM
SPANKY LS1's Avatar
Default Cometic thickness questions....
Just wanted to verify that Cometics thickness is given compressed, right? A Cometic .040 is .040 compressed right?
Thanks, Shawn
Old 01-26-2005, 11:33 AM
jrp
SN95 Director
jrp's Avatar
yes, the number stated is the compressed thickness. i went with the .045 cometic myself.
Old 01-26-2005, 12:19 PM
LS1Tech Sponsor
Slowhawk's Avatar
Yes it is.Just make sure you retorque them 3-4 times.Cometics can be a pain to compress right.I personally like the GM MLS's at .054.I've done the ultimate quench testing and there was no HP gain on the LS1's so I like spending $25 a gasket instead of $75-$100 per gasket for Cometics
Old 01-26-2005, 12:27 PM
Jimm's Avatar
Old 01-26-2005, 12:29 PM
jrp
SN95 Director
jrp's Avatar
what was your retorqueing regiment? i torqued and retorqued mine during thee installation of my ARP studs. the engine hasnt been fired up yet, once broken in whats the retorqueing schedual?
and when your already thousands upon thousands into a project whats 75$ per gasket
Old 01-26-2005, 02:21 PM
HAMRHEAD's Avatar
I am curious as well.
Old 01-26-2005, 02:32 PM
RX-Ben's Avatar
Quench doesn't give HP gains, it simply wards off detonation and allows higher static compression ratios and more timing.
Cometics are also reusable, from what I've read.
Ben
Old 01-26-2005, 05:59 PM
OnE Ls1 2 HaTe's Avatar
so then the cometics would be better for nitrous becuase of them warding off detonation?
Old 01-26-2005, 06:28 PM
crow2's Avatar
Thanks, Shawn
Just to touch on this~yes they are .040,you can also get .051"~or they can make you whatever you want reasonable per application.but .040 is the norm,or like .045 like some people like!great gaskets!
Old 01-26-2005, 07:07 PM
LS1Tech Sponsor
Slowhawk's Avatar
Go over the torque again before startup,then you should be fine. So far out of 4 motor's I put Cometics in,3 of them leaked.This was 2 years ago and I gave up with them.Now we just use MLS gaskets. 90% of our cars are running FI so we do stress these gaskets
Old 01-26-2005, 07:14 PM
Louis's Avatar
50+ Heads/cam jobs with the right mill and never a leak, Torqued twice.
Old 01-26-2005, 07:21 PM
LS1TECH Sponsor
mikey's Avatar
I use Cometic almost exclusively on my 400+ CI motors and not a problem but I use a bonding agent around the coolant passages. Cometic says no, I say yes The deck and head surfaces need to be perfectly smooth though. Never had a leak!
GM MLS gaskets do work better on 346 applications. They are a no-brainer.
Old 01-26-2005, 07:31 PM
pdd
pdd's Avatar
Ben
i thought with the perfect quench, you gained more power guess id better torque down my cometics again
Old 01-27-2005, 08:47 AM
Mirek's Avatar
Do you need to retorque with gm tty bolts too ?
Old 02-01-2005, 09:34 AM
crow2's Avatar
I did some checking for you on your question.According to GM,you do not re-torque the bolts.Retorque could affect the TTY bolts !
Old 02-01-2005, 10:43 AM
Mirek's Avatar
Thanks Good looking out.
