o ringed 6.0 iron block
LS1TECH Sponsor
We can fully machine you a block and install the o ring. Or just install the o ring. You can also send us the heads and we will reciever groove them. Both procedures are done on our CNC. They will match up perfectly. I also have SCE Titan copper gaskets for the 6.0L block.
Bryan
LME
713-849-4505
Bryan
LME
713-849-4505
11 & 7 Second Clubs
You must be planning to squeeze that dude plenty hard. If you are going to o-ring and receiver grove the block and aluminum heads, you should drill and tap the block for 9/16" head studs. An even better combo would be to use p/p 6.0 L c/i heads. You could then put 20 lbs of boost and 200 shot on it with ease.
