Question concerning wiring up lighting for fuel pressure gauge
I've got an Autometer elec fuel pressure gauge that I have wired up and works fine. The problem is, I can't seem to locate the wire which provides the backlighting. I thought maybe I just had overlooked it, but there isn't one. I just pulled the gauge out of the pod and there is no white wire in the wiring harness that plugs into the back of the gauge. I'm not sure if maybe I'm suppose to tap into the red wire coming out of the gauge? It looks like that might be the case according the picture in the instructions, but I'm not totally sure.
Here is the link to a pdf of the install instructions for the gauge
http://hp.autometer.com/instruction...instruction.pdf
