Better daily Driver Cam… TSP Torquer or 233/239 or HPE “S” Cam or what?
Old 01-29-2005, 10:50 AM
SebastianLopezJr's Avatar
Default Better daily Driver Cam… TSP Torquer or 233/239 or HPE “S” Cam or what?
Thought I had my mine made up, but now read different things all in my searches. Wanting a good daily driver cam that will work well with a 3500 stall auto, bolt-on, true duals car. Thanks for the help & suggestions.
Old 01-29-2005, 10:58 AM
Beast96Z's Avatar
The "S" cam is cut on a 115 LSA where as the TSP cam is cut on a 113 LSA. Both cams have a varable split, but I believe the S cam has a little more to make up some overlap. I'm gunna say the S cam would be more "tame" for your particular application.
Old 01-29-2005, 11:07 PM
hugger1975's Avatar
i am getting a 233/239 in 3 weeks................
daily driver.
Old 01-30-2005, 09:24 AM
JaSSon's Avatar
Get the FM13, you dont want much more for a DD.
Old 01-30-2005, 09:59 AM
Bill Bowling's Avatar
Talking
I have the Torquer waiting to be installed in my daily driver.
Bill
Old 01-30-2005, 02:18 PM
Old 01-30-2005, 11:17 PM
gnx7's Avatar
TSP 233/239 daily driver
I want 10's n/a.
-GNX7
Old 01-31-2005, 01:09 AM
luv2spd's Avatar
I have the torquer and while my car doesn't have dd duties, it very well could be. Drivability is excellent with this cam!
Old 01-31-2005, 01:24 PM
2000Hawk's Avatar
have the 233/239 sitting in my room waiting for installation, into my daily driver. also got it with the whole PRC Dual Valve Spring Kit.
Old 01-31-2005, 03:59 PM
Gamefan008's Avatar
I'm thinking about a 233/239 for a daily driver this summer
Just a question though... on the LSA, why is it 112+2
I'm confused as to what the +2 is
Old 01-31-2005, 04:12 PM
Dont know, good question. Anyone know can help?
Old 01-31-2005, 04:20 PM
fast98's Avatar
+2 means the cam is advanced 2 degrees when it is straight up or dot to dot. it basically lowers the powerband
Old 01-31-2005, 04:21 PM
Moderator
thechef's Avatar
the key to all of these bigger cams is TUNING for daily driving with a good tune you will be fine
Old 01-31-2005, 04:29 PM
cyclerage's Avatar
I ordered it, just waitin for the postman now.
Old 01-31-2005, 04:34 PM
Gamefan008's Avatar
So is it basically like a 114 LSA? or does it have anything to do with the LSA?
Thanks for the help btw
Old 01-31-2005, 04:37 PM
CT Hotness
lilstephsls1's Avatar
torquer is going in my car this spring for dd purposes
Old 01-31-2005, 04:53 PM
Stryker's Avatar
exactly same situation im about to change in the upcoming week.. im sick of lookin at them and not actually feeling them in the car
Old 01-31-2005, 05:05 PM
CamTom12's Avatar
No, doesn't have anything to do with the LSA. That stands for Lobe Separation Angle, or how far apart the peaks of the lobes are.
The +2 just means that the cam is advanced 2 degrees, which is the same as putting the cam in the car, then turning it two degrees forward of the crank.
Here's a diagram to help explain LSA:
Gamefan008's Avatar
I just hope i can throw together the money.
I wanna finish up the bolt-ons first, then wheels... THEN cam
Old 01-31-2005, 05:06 PM
Gamefan008's Avatar
Quick Reply: Better daily Driver Cam… TSP Torquer or 233/239 or HPE “S” Cam or what?
