TR224 valvesprings , pushrods, lucks, retainers !!
i didnt want to bother u guys with this old issue , but am in it right now i contacted Thunder and am waiting for their answer for the BEST valvesprings, pushrods,lucks, retainers to be use with the TR224 , i searched the forum looking for an answer and i founded many answers some with the comp 918 and stock retainers , lucks and pushrods !! and some with the hardened pushrods (stock length)
need ur opinion , cause ive heard that some comapnies just wants u to get the one they have and the one that cost u much !
wahhab
wahhab
wahhab
wahhab
Just my opinion.
Technically you can resuse your stock retainers and locks and the 918s seem to be the standard with that cam. (same as I have) However I think the TR224 is a small base circle cam therefore you need a longer pushrod if you don't mill the heads.
Are the manley dual springs (rated at over .600+lift) to much spring for the tr224??? im thinking of getting this cam, but the heads im getting are coming with those springs.
-Ryan
-Ryan
I bought the patriot performance dual valve spring kit for extra insurance, and just incase I want to move up to a bigger cam in the future. Not to steal the post, but is there such a thing as TOO MUCH spring for a cam?
Just something I've heard.
-Ryan
Originally Posted by VaNDaL*SS*
I have heard that their is such a thing as too much spring. If the spring is too stiff and you dont have a cam that has enough lift then it could wear down ur cam faster, due to the excessive force on the cam.
-Ryan
-Ryan
The Thunder Pushrods are actually 7.415" long so they counteract the .0015" smaller base circle on the TR224. Using a 7.435 PR is wrong unless your heads have been milled. I used to run, TR224 C918s TR PRs @ titanium retainers. Weight is the enemy of any valvetrain and you'll be doing yourself a favor coughing up the $90 for titanium retainers. After finding the spring pressure was low on the 918s after 4800miles I pulled them when I installed my Patriot heads w their .650 lift Gold springs. I think the 918s are great designed springs when you read up on the harmonics of a beehive design spring compared to duals. I am pretty sure mine lost pressure due to the added weight on the valve caused by my Yella Terra 1.7 roller rockers. If I was running the stock rockers I would have no reservations about running the 918s again. HTH
Originally Posted by Droptopws6
Listen, just use 918's , ti retainers and 7.4" TR pushrods. You dont need the dual valve springs,overkill.
I'm kinda new here, but where are you guys getting all this BS about push rod length..
TR , Comp, Crane, stock LS-1 rods are all 7.40"
Then I guess the guys at Thunder lied to me and my dial calipers don;t measure correctly.
