moser leaking from all seals!!
Old 01-31-2005, 03:48 PM
pewterta's Avatar
Default moser leaking from all seals!!
both my axle seals are leaking... my pinion is leaking...and my trans seal.(were it connects to the drive shaft) is leaking!!!!
not over filled..either..any ideas...and any part nmbers would be very helpful
thanks u so much!
shawn
Old 01-31-2005, 05:21 PM
69chevy's Avatar
just an idea but just check the bolts or whatever to see if they're tight. maybe they didnt tighten them all the way or something
Old 02-01-2005, 09:33 AM
LOnSLO's Avatar
Also check your housing vent. If it's blocked or pinched, it will leak out of everywhere.
Old 02-03-2005, 04:08 PM
pewterta's Avatar
yea the hose is fine..i cant imagin that is hard to cloge or be pinched it stands straight up
Old 02-03-2005, 05:12 PM
peterock98's Avatar
Did you put synthetic fluid there?I see you have a moser .My strange 12 bolt was leaking from the pinion seal with less than 1000 miles on it. When I called them that was the first question he asked me.
Old 02-03-2005, 06:10 PM
studlybilly's Avatar
You'd be surprized how much junk gets globbed in there, I've even had to take a small drill bit and ream some out before. If it happens to be leaking out of ALL seals, then my bet is going on a venting problem.
Old 02-10-2005, 02:43 PM
pewterta's Avatar
changed out axle seals ( cheap japeneses ones were in there..damn moser!!) and pinion seal..
well see what happens..so far dry as a bone
