42# injector non-mist??
By 'don't mist' do you mean printle style (looks like a needle & seat) instead of the disk style (stock, has a disk with holes in it)? If yes, then Bosch, SVO & Accel are all that style.
So the most popular aftermarket injectors are pintle style? That's odd, I thought all modern fuel injectors used the multiple holes, to provide better atomization. I know the motorcycle mags made a big deal about the newer models going from 6-hole injectors to 12-hole.
Is a pintle style just as effective, or just cheaper to manufacture?
The stock disc type are the ones you want. They have a very narrow spray pattern compared to SVOs and the like, which are like a 30 degree cone pattern. You want the GM Delphi 42s. I don't have a part number handy for you, though. That's what I'm running, and after comparing them to SVOs on an injector machine, I will always use these.
