Big cam in Stage III heads..
I was looking around for custom grinded cams for a nitrous car and I cam across a TSP grinded 237/242 .602/.611 @113 cam. I was looking to put it in a car that has Stage III 6.0l heads, 2.02/1.60 valves, dual spring, milled to 11:1 compression. My question is; would I run into problems with clearence with that much lift. The heads were decked for a much higher compression so what would be the highest lift I could go with?
Originally Posted by jrp
assuming a stock gasket, 6.0 heads would need to me milled ~.070 for 11.1 CR. so ya, you'll need to flycut to use the MS3
