KR/4 degrees: How much HP am I loosing?
Old 02-02-2005, 11:32 AM
Magyver's Avatar
Default KR/4 degrees: How much HP am I loosing?
I think I fixed it, but won't be able to check for sure until tomorrow. I was wondering how much HP could it be robbing me off. Before my headers install I put on average 311 to the wheels. Done about 3 dyno sessions. I had a tube that was vibrating when I put the headers. We found KR after the header install also. I got what I think was causing it welded. After the header install 318 to the wheels. Going to dyno again before I install my cam and make sure the KR is gone.
http://macgyver.100free.com/AIRTUBE.jpg <---copy and paste for it to work.
Old 02-02-2005, 11:47 AM
DanZ28's Avatar
You can check your KR without dynoing if you have A-tap or similar. Is KR only at WOT? What is your max timing? Don't know what it would be in HP, but I bet it's in the neiborhood of 10 HP or so depending on if it holds 4* of KR or that's just the max KR and drops. need to log some data..
Dan
Old 02-02-2005, 11:54 AM
Magyver's Avatar
Dan
Used my friends hptuner/laptop. It was above 4k and it held. If I remember 26degrees down to 22 after 4k. We have a few recorded logs and consistently above 4k during a hard run. Can't remember if the log said at WOT but I know one run I didn't go hard but go it above 4k and no retard. So I assume 4k and WOT. Really knew to using these hptuner or any at all. My friend has a little.
Old 02-02-2005, 06:02 PM
MNR-0's Avatar
You stand to lose 20rwhp with 4* knock
Old 02-03-2005, 08:49 AM
Magyver's Avatar
Old 02-03-2005, 09:54 AM
Moderator
jimmyblue's Avatar
According to the stock PCM % Torque Loss vs Spark Retard
table (HPTuners 1.6) it's 1% at 6 degrees, I make it 0.4% at
4 degrees. Figuring 350 lb-ft of torque that would only be
1.4 lb-ft lost. But the table is not something I particularly
believe.
Thing is, if you are pinging (for real) you are well past best
torque timing and pulling back -could- actually help you.
But the knock retard is excessively jumpy and slow to
recover, often kicked in by transient throttle to mess up
your subsequent steady pull, and sometimes all about
false pickup.
What I've seen says, MBT timing is about 2 degrees less
than onset of ping. So if you were 2 degrees into ping
and pulled out 4, you'd be doing great. Not that the KR
setup can be counted on to put you there, properly.
Old 02-03-2005, 10:15 AM
Magyver's Avatar
believe.
false pickup.
This afternoon I will be recording more logs with my friend who has hptuners. I will post up the findings tonight. Your theory sounds right, but I hope it is wrong. Going from 311 without headers and up to 318 is a disappointment. My long and short term fuel trims are off. I don't know if that is hurting me much. We haven't dealt with it yet b/c we are putting the cam in next saturday.
