Tuner reccomendations for injectors for 15 psi boost
I am currently rebuilding my engine and need a reccomendation on injector size and brand. I have a 346 block with 9:1 compression pistons, 288/295 222/224 cam on 114 lsa, walbro 255 in tank pump and I plan on turning my D1-SC up to 15 psi. how big of an injector do I need to keep up with the boost. Also is there anything else I need to upgrade to make everything run well? Thanks
Coal Mining Director
Since you only want to spend money once...buy the mototrons 60's...you may need a msd boost a pump for the fuel pump or go to dual pumps at that boost level...only a dyno tune will tell you for sure when you get everything finished.
