LS1 , LS6 or FAST LSX????
Old 02-05-2005, 04:49 AM
Trans_Am05's Avatar
Default LS1 , LS6 or FAST LSX????
ok guys I know this is going to sound pretty newbie but I just want to know. I know some diffrences between all these intakes but I want to know what the main diffrence in them are. And what will give me more power and LS6 or FAST LSX intake. Just let me know what the diffrerences are and which is better. THANX
Old 02-05-2005, 05:39 AM
goober35's Avatar
LSX will flow more air but you will not see a noticble amount of power unless you have ported heads and a cam. If you get the lsx intake get the 90mm not the 78mm.
Old 02-05-2005, 07:49 AM
destroyerSS's Avatar
Buy the LSX and be done with it. no sence in leaving HP on the table down the road if you plan on doing more MODS!!
Old 02-05-2005, 10:18 AM
LSUxBlake's Avatar
There is very little difference between the LS6 and 78mm LSX. The 90mm LSX will not help you until you have at least heads/cam.
Old 02-05-2005, 11:10 AM
nspr8td lt1's Avatar
alot of people overlook the fact that the lsx manifold comes setup for direct port and has a burst panel.
Old 02-05-2005, 11:29 AM
cyphur's Avatar
you can go with the LSX 90mm setup if you plan on a healthy cam, its shown that it will be beneficial. nothing crazy but it WILL help some. if you don't plan on too many mods for the time being, an ls6 intake will suit you just fine.
Old 02-05-2005, 12:22 PM
PHANTA-Z's Avatar
On the few cars Ive seen it tested on, it hasn't been worth the near the money they are getting for it. Granted, I haven't seen a back to back comparison of it vs LS6 on a big cube or built power-adder car, so in that instance it might be worth the ~$1600 (intake and tb).
Old 02-05-2005, 01:31 PM
LSUxBlake's Avatar
It's 2 times the price of the LS6 though, and the burst panel does not come standard on it.
Old 02-05-2005, 01:53 PM
TAQuickness's Avatar
I thought this was intersting... https://ls1tech.com/forums/generation-iv-internal-engine/268277-ls6-intake-ls2.html
