Got my Ltrims in line....now I have a bigger question...
Old 02-05-2005, 10:14 PM
99FormulaWs6's Avatar
Default Got my Ltrims in line....now I have a bigger question...
I've lined all my LTFT's out so that they are either -1, -2, 0, or 1. Now I took my car to a guy on the same forum as me and he pointed out that I had a 85mm MAF, and that we need to scale for it. After we did this it went way lean and we could not get it anywhere near close, so we started completely over, we changed the IFR to adjust for the 30#SVO's and the MAF table to adjust for the larger MAF and we still could not get it anywhere near close. Anyone have a clue as to what we were doing wrong?
Old 02-06-2005, 08:52 AM
Billiumss's Avatar
You are trying too hard. If your Ltrims are fine after 30-50 miles, then you are ok. Now your WOT PE table needs to be tweaked on the dyno...
Old 02-06-2005, 02:15 PM
So even though my pcm is calibrated for the wrong maf, it won't affect the power I make?
Old 02-06-2005, 02:25 PM
Tiger2o69's Avatar
what maf do you have? z06, slp , ect.
Old 02-06-2005, 03:24 PM
it's a delphi 6.0 liter MAF, we used the numbers posted on here to calibrate it.
