4L60E & Code P1870
4L60E & Code P1870
I have a stock 1998 S-10 which I rebuilt the transmission with new converter (No shift Kit) about 3 weeks ago and just yesterday had code P1870 flash.
When driven cold all shifts and performance is perfect. When highway driving for 10 miles 60mph and returning to city driving the 1-2 shifts become harsh. Code P1870 is indicated.
I did notice that the valve body plate had slight upset metal where the ball checks contact the plate.
My question: Is this the worn converter valve issue
in the valve body if not what else should I inspect. Upon disassembly of the valve body & converter valve would it be obvious that this is the problem. Which specific kit (Transgo & Sonnax) should I be using to correct this problem.
Should I check any other areas first such as if speed sensor is OK, although this should have been indicated on the analyser.
Thanks!
Thanks!
those septerater plates go out all the time my old truck ate one up every 30k miles, the check ***** some times break threw the plate....transgo makes a replacement that is harden tool steel or something and zinc plated.....try that you can get them from ebay for like 22 bucks shiped
http://cgi.ebay.com/ebaymotors/ws/eB...category=33727
tell brian keyguy2002 sent ya
