AFR and Cam selection,some info
I've been messing around with a few Cams in 1 car and have found out some good stuff.
The Car has a stock 346 shortblock with AFR 205's untouched,Hooker longtubes,ported LS6 intake/TB,underdrive pulley and a 9" rear with 4.10's.
So far from what we have tried bigger is not alway's better.We had a TR 230 in the car when the heads went on,tested that out then tried a Cam in the range of 232/238 and lost alot of midrange power,then gained some above 5500rpm.Then switched back to a custom reverse split grind under 230 but higher lift and gained it all back and then some.Driveability is a hell of alot better too.
This is very vague untill I'm done with testing the Cams out.When I'm done I'll post it up.For now I see reverse splits making alot more power,better drivability than traditional splits
How did you come about that observation of the reverse split being better than the traditional? I assume you have been testing this theory, can you share your results? I am curious about this because the Stealth II cam has horrible performance with the AFR 205 heads in comparison to a traditional split. Even Tony says that reverse splits didn't do as well in their testing as traditional's. Keep us informed...
Dan
Dan
Dan
Dan
I know AFR has done there homework on there heads.I'm just sharing result's of box stock AFR's, no milling,stock GM MLS gasket's(cheap compared to Cometics) and LS6 intakes.
Originally Posted by Slowhawk
Driving,tuning,dyno testing (tracks are closed). This is hands on testing,not theory's.I've been lucky enough to tune/dyno other customer's cars that have installed AFR's too,so that helps a bit on top of my own work
Not doubting or anything, just very curious
It's always a good thing to have actual results, I agree. I know your still testing, but what do you mean by "alot more power"? Are you getting better results than the AFR cams or the G5X3 cam? What standard splits are you using? XE-R lobes?
Originally Posted by jrp
are these reverse throughout the whole lobe profile? and how big of a split.
I use to do all the math,flow's ect and the result's are not what they are suppose to be.I'm finding out with actual testing that stuff that shouldn't work actually works better
SN95 Director
I knew you would ask that I'll let you know in the future
im very interested in the results regardless, its funny how theory doesnt always work in practice.
I measure the midrange power mostly.The bigger Cams peak higher in HP but I would much rather have more power from 2000rpm to 5500rpm,that wins races I've been trying different lobes too with some good result's.
If you want low and midrange power for a street car, obviously a beast cam is not the appropriate choice.
Originally Posted by JF WS6
It depends on what kind of racing your talking about. No doubt the smaller cams with better mid range will be better driving on the street and more punchy, but if you are drag racing against the bigger cam car who is dumping the clutch at 6Krpm (or a 4000 stall auto) with a 4:56 geared 9 inch on slicks I'd bet on the bigger cammed car that shifts at 6800-7k rpm and has noticeably more peak HP.
lol, i justs want to do a bit bench racing before i can test out my own "reverse" split
Yeah, kinda funny you mention that. A friend had a custom grind made after reading some of the "Camshaft Discussion" threads and speaking to a few people about it. The cam he had ground wasn't suppose to idle, surge like crazy and engine was suppose to run like ****.
Well, it lopes a little, idles great and made 410hp/395 tq (iirc on torque), cam only, with an ironing board torque curve. Something along the lines of "222/226". Hell thats more than most heads and "my dick is bigger than yours" cams. We aren't experts or pros but one things for sure, Ed Curtis wasn't kidding!
Yes,I agree to a point.To take advantage of the BIG Cam and high gears you need your car to be very light.Most of the BIG Cams torque drop too much up top to move our heavy cars.Probly about 95% of the people that own LS1's should be running midrange setup's. Also the Cams I'm going through have all pulled to 7000rpm without dropping hp.
I'm sure most of the cams you've tested didn't lose HP at high rpm, but they didn't gain over the big cams at high rpm, correct? I'm sure the bigger cammed setups most likely are making more power on average from 5500-7000 wouldn't you agree?
I agree with your comments, but mostly in regards to a street car type set up that is nearly full weight. I guess it depends on what you consider "very light" as well. There are a few board members who have 10 second cam only cars with the TREX that are 3400 lbs. or so that got faster with the bigger cam. The lighter the car, the better the gains of course, but that could be said with any car. The lighter it is, the faster it will be.
This is good info.
I am on the fence deciding whether or not to add AFR's (unmilled) to my G5X-2 cammed C5. The split is similar to what you have stated here if I remember the numbers correctly. (232-240 ??)
Looking forward to your results.
