? about pinion seal
? about pinion seal
My rearend is leeking at the pinion seal. I was wondering if when I replace it if I can mike the crush sleeve and replace it with the solid spacer and the proper amount of shims? The rear is not making any noise so I beleave it's OK.
I'll bite, why make the crush sleeve? Arent they cheap enough already? Or are you looking at a means of a better design which I'll tip my hat and say goodluck.
Originally Posted by slow98Z
so can it be done or what ttt
I would just replace the seal and let it go..
what do i need to replace it? torque spects???
i dont know the tq specs but i went and bought a 4" piece of pvc pipe from home depot that fit inside the ring and hit it in like that. cause its a bitch to get in to begin with.
