Stereo & Electronics - Power Antenna Part#?
View Full Version : Power Antenna Part#?
IR8SS
02-07-2005, 06:21 PM
I was wonder if this is the right Part # for a Power antenna 10402860?
02blackSS
02-07-2005, 07:49 PM
I have 10402859? They both may be the same.
WhiteBird00
02-07-2005, 08:20 PM
Part number for Firebird is 10402860. Part number for Camaro is 10282646. Don't know why they have different numbers - they should be interchangeable.
VIP1
02-07-2005, 08:24 PM
The Camaro's antenna is a fixed mast, it is not powered. That is why it has a different part number.
Here is another thread on the topic:
(one of many)
http://www.ls1tech.com/forums/showthread.php?t=188414&highlight=blackcamaro
WhiteBird00
02-07-2005, 08:36 PM
(one of many)
You know what? I can read a parts manual better than that. The part number for the fixed mast Camaro antenna is 10425536. The one I quoted before is listed as "Ant, Radio Pwr (U75)".
VIP1
02-07-2005, 10:46 PM
I wasnt being rude. You didnt say that you have a manual with them listed. I just thought that you had it written down somewhere and didnt know what it was. Sorry.
IR8SS
02-08-2005, 07:19 AM
So whats the difference between 10402859 and 10402860? Are they the same?
WhiteBird00
02-08-2005, 09:10 AM
I can't find 10402859 in either the Camaro or Firebird parts books but it is a valid number and is still available (although it's a few dollars more expensive than the 10402860). Where did you get the number? Off the antenna itself?
IR8SS
02-08-2005, 09:26 AM
No, Im looking to get one. I got the #10402859 from a link in this post and i looked it up through gmpartdirect.com and like u said it is a few dollars more but im just wondering if they were the same. When i looked them up the 10402859 was for a camaro and the 10402860 was for the firebird. So will either one work?
WhiteBird00
02-08-2005, 09:40 AM
Consecutive numbers are often used for left/right, Camaro/Firebird, etc. It's likely that 10402859 is the correct part and that my bootleg parts manual is showing either an earlier number or a later replacement number (I don't have a publication date for my parts manual).
IR8SS
02-08-2005, 09:45 AM
Could it be that the numbers are model specific. Like the 859 for chevy and 860 for pontiac?
WhiteBird00
02-08-2005, 09:48 AM
Well, yes, that's probably the case although I can't think of any reason that they would be different. The curve of the inner quarter panel is the same for mounting and there is only one electrical connection so they should be interchangeable. I suppose the hole for the mounting brace might be in a slightly different location or something.
IR8SS
02-08-2005, 09:50 AM
Thanks for all the help.
