Can the oil pan be dropped w/ a BMR k-member w/out having to lift up on the motor?
put a couple bolts in the pan, jack up the motor by the pan until you can slide the two motor mount bolts under the mounts. That will hold the motor up high enough so the pan will fall right out with the BMR, if your headers are still bolted on the heads and the intake is on make sure you dont crush anything trying to jack it up high enough, I'm not sure it will make it if the intake is still on - mine was off when I did this.
