Suspension & Brakes - HELP! 32mm F.swaybar bushings????
Vertigo
02-07-2005, 10:52 PM
I went by the GM dealership to see if I could pick up some bushings for my new Front Swaybar 32mm. They had no idea what bushing to use b/c all they had in their computer was Suspention type F1, etc,etc,etc, . Does anybody know what type of bushing i need so the GM techs can sell it to me or if you have a gm part # for a 32mm fswaybar bushing that would be the best thing! THX!
black00TA
02-07-2005, 11:44 PM
32mm is the size that came on 1LE camaros im pretty sure 98 z28 mostly, they have to have them because they came stock on some f-body's
Vertigo
02-08-2005, 09:29 AM
Do you know the suspension code for the 1LE? F1 ? or if anyone could give me that part of their VIN that specifies that it is a 1LE would work also. THX!
black00TA
02-08-2005, 11:21 AM
why dont u try ordering some poly bushings from some of the sponsers..... they make them in 32mm
Vertigo
02-08-2005, 06:01 PM
What sponsers carry these in Solid Rubber? and what all do i need to get my 01 Z to adapt a 32MM solid Front sway bar...just bushings? or do i need new brackets, etc? THX!
black00TA
02-08-2005, 06:50 PM
just bushings...... i put a 1LE 32mm on mine but i opted to buy new poly endlinks and bushings, your going to need new D dushings anyway. if u just look under there and look how it is hooked up you would understand a lot more. spend the money on the poly bushings... its like $30 for everything u need and its higher quality stuff..... get the most out of your swaybar while your there.
Vertigo
02-09-2005, 06:40 AM
THx man you've been a lot of help! I appreciate it! :)
biggreek33
02-10-2005, 06:56 PM
black00ta is right energy suspension has some good stuff i just bought my 32 mm front swat bar polyuirethane bushings there pretty cheap and way better than stock.call summit racing and order them great prices fast delivery. good luck
Vertigo
02-24-2005, 09:58 AM
Ok guys I just ordered Energy Suspension's 31.5mm front sway bar bushings from summit. great price btw!
Any tips on install?, binding prevention, etc?
:usa:
mitchntx
02-24-2005, 10:16 AM
I got poly bushings by Moog from O'Reilly's
black00TA
02-24-2005, 06:56 PM
use a healthy dose of grease/lube on all bushings.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
