Who built your 200R4.
Old 02-07-2005, 11:52 PM
Ryan1985's Avatar
Default Who built your 200R4.
Who did yours? How much and what all would i need to go with it? How well is it holding up?
Old 02-08-2005, 08:38 AM
93LS1RX7's Avatar
Del-Trans did mine. It is holding up well but I have a much lighter car.
Century Transmissions did the TSP car and theirs is running real fast.
Old 02-09-2005, 11:27 AM
LS1Tech Premium Sponsor
Trevor @ Texas Speed & Perf.'s Avatar
As mentioned, Century Automotive built our 200-4R. Mike at Century is the only transmission builder that touches our autos. We have really abused our 200, and it doesn't blink an eye. I ran it for a year in my '02 SS before putting it in our '98 Z28, and I ran a best of 10.13 @ 131 MPH on a 1.39 60' with it. I sent it back a year ago for freshening, and Mike said everything looked perfect. The 3-4 clutch pack was showing a little wear but nothing bad by any means, but I had him replace it anyways while it was there. We put the trans in our Z28 last May, and we've run a best of 10.20 with it with numerous 60' times in the high 1.3x range.
The 200-4R conversion is not cheap, but Century's transmissions are well worth it. Spend the money the first time to do it right, and you won't regret it. Feel free to give me a call or shoot me an e-mail at trevor@texas-speed.com, and I can put together a complete conversion package for you.
Trevor
Texas Speed & Performance
__________________
Old 02-09-2005, 11:06 PM
Ryan1985's Avatar
sounds good i would just like to have a tranny that i dont have to rely on the computer to shift right and could put a trans break on sometime, It will be alittle while before i do this though,. I want to get a rearend and all the suspsion to handle the power before i put some power to my car. Just wanted to get some info on it. What all is required in the swap? reflash computer,converter, x-member i guess. what else? Does the 200 bolt right up or is there a special bell houseing used?
Thanks
Old 02-10-2005, 01:37 PM
93LS1RX7's Avatar
Bolts right up but only uses 4 of the 5 bolts. They make an adapter to use all 5 bolts but it isnt necessary.
Old 02-10-2005, 02:18 PM
Ryan1985's Avatar
what bolt does it not use? a top one or a bottom one.
Old 02-11-2005, 12:16 PM
slowbird21's Avatar
Man that tranny already given you hell, hope you can get it fixed before you get your *** handed to you in the itty bitty ford lol
Old 02-12-2005, 11:55 AM
69firebird's Avatar
the only problem with the century transmission is that it is like 5k with their converter
Old 02-12-2005, 01:05 PM
10 Second Fun Car
jlrz28's Avatar
I dont know how much power your looking at making. I got a 4l60e from Century and love it! They rate it at 500hp 500ftlbs. Its been a great transmission and there service is top notch! give em a call (866) 869-8120.
Old 02-12-2005, 10:41 PM
Ryan1985's Avatar
Thats it ***. Im scared of that POS mach 1.
Old 02-13-2005, 12:59 AM
slowbird21's Avatar
You are a funny guy I guess I will see you at the track then
Old 02-14-2005, 02:32 PM
ls1itldo's Avatar
You don't have to run Century's torque converter. I had TCI custom-build a converter for my 200-4R with no problem whatsoever. I can get you a custom-built TCI for the 200-4R with the LS1 pilot length and bolt pattern starting at $515. The price will vary some depending on stall speed, but it will certainly be cheaper than other custom-built converters.
Trevor
Old 02-14-2005, 02:47 PM
93LS1RX7's Avatar
It doesnt use the top bolt.
Old 02-14-2005, 10:20 PM
KLHAMMETT's Avatar
CKPERFORMANCE out of New York is the best in the country with a 2004r
Check their website or Call Chris (owner)He also has a fantasic electronic transbrake available for the 2004r
Tell him Otto sent you
Last edited by Ragtop 99; 02-15-2005 at 11:29 AM. Reason: non-sponsor contact info
Old 02-14-2005, 10:50 PM
Ryan1985's Avatar
Trevor
are they lock up converters?? Im gonna try to do this and a 12 bolt by next seseson. Thanks for the link KLHAMMETT. Ill deffintly look into them. I see they have replacment trannys for defferent cars does it matter which one its for.
Thanks for all the help guys
Ryan
Old 02-15-2005, 06:08 AM
KLHAMMETT's Avatar
Ryan
I dont believe so,He has most valve body to build a core to specs for most or the Factory performance applications.
He also builds a Hybrid AOD that they are using in 8 sec car reliably and still reatain OD
Old 07-17-2005, 04:02 PM
69firebird's Avatar
is their hybrid AOD stronger than a 200r4?
Old 07-17-2005, 08:26 PM
JonB's Avatar
Check out these two sites they both do excelent work.
Bowtie overdrives
Performance Transmissions
I personally have you from Perforamance transmissions along with on of there restalled D5 converters in my 88 Monte SS. These two come highly recomened over on Turbobuick.com and MonteCarloSS.com.
Quick Reply: Who built your 200R4.
