Will an LS1 4L60e work with an LT1 - are they the same?
Old 02-08-2005, 01:11 PM
MeanWS6's Avatar
Default Will an LS1 4L60e work with an LT1 - are they the same?
Old 02-08-2005, 02:24 PM
GregWS6&z28's Avatar
i belive splines are different, bellhousing, and converter
Old 02-08-2005, 10:54 PM
lessthen12's Avatar
I am 100% positive that they won't bolt up you would have to get an adapter for the bell housing bolt pattern. Plus I'm not for sure but I believe the ls1 2 piece case is a little bigger then the LT1's 1 piece case.
Old 02-09-2005, 12:57 PM
maddboost's Avatar
Different bellhousings and different electronics. You can convert a LS1 4L60E over to use on a LT1 but its not a direct swap.
Old 02-09-2005, 02:07 PM
68birdls1's Avatar
just drill som wholes in it and call it the day lol! j/k but there is a conversion for it somewhere.
Old 02-09-2005, 02:53 PM
prostock_bigblock's Avatar
I had been damaged alot of 4l60E gears , so the main differences are :-
1- bell housing
2- torque converter
3- elctrical differences( sensors , harness connect )
4- input and also the output shaft
5- gears drams (the lt1 have the same 700R gear dums)
6-gear oil pump.
there are 1 or 2 things also that i dont remember
Old 02-09-2005, 02:54 PM
sorry ( drums ) .
Old 02-09-2005, 04:47 PM
DriveATransAm's Avatar
check your pms on mfba.
