Shaft mounted rockers and valvetrain geometry?
Old 02-09-2005, 11:14 AM
silent1's Avatar
Default Shaft mounted rockers and valvetrain geometry?
How can you adjust for proper geometry on shaft mounted rockers when their "height" is pretty much set by the rocker stand? I'm using Jesel adjustables, thanks.
Old 02-09-2005, 11:18 AM
I can shift faster than you.
Jason99T/A's Avatar
You are going to need to shim the stand up or have the stand cut to get your valvetrain geometry correct.
Jason
Old 02-09-2005, 02:55 PM
DAPSUPRSLO's Avatar
I asked many questions about this and got some good responses, including some from Jason above. Do a search under DAPSUPRSLO and you'll find some of the info you are looking for.
Old 02-09-2005, 04:20 PM
silent1's Avatar
Thanks alot fellas.
