Metal-dragging-on-concrete sound when accelerating
Old 02-09-2005, 11:18 AM
ttyson's Avatar
Default Metal-dragging-on-concrete sound when accelerating
When I go from a dig in my car, just normail stoplight city driving, from 0-2000 rpms i can hear this sound from the car that sounds like taking a piece of sheet metal and dragging it behind the car. once the car gets over 2000 rpms, the sound goes away instantly. this continues when i shift into each gear.
when the clutch pedal is depressed, or the transmission is in neutral, and i give it a little gas, there is no sound
it is a 99 z28 M6 with no mods except !FRA
any ideas? i have not noticed any power loss, but it is just annoying
Old 02-09-2005, 11:25 AM
Cal
Cal's Avatar
See if the drive shaft is rubbing on the tunnel brace.
Old 02-09-2005, 11:26 AM
ttyson's Avatar
wouldnt i be able to hear that through all RPMs though?
Old 02-09-2005, 11:35 AM
Cal
Cal's Avatar
It could be it only does it when the engine is putting out more torque and loads the suspension so something rubs. It could be the I-pipe rubbing the driveshaft also.
Old 02-09-2005, 11:39 AM
ttyson's Avatar
gotcha
i thought it was something worse like throwout bearing or transmission issues
how can i check that seeing as how the sound only occurs when the car is in gear and moving?
Old 02-09-2005, 11:40 AM
Wile_E's Avatar
Originally Posted by ttyson
gotcha
Look for scratch marks on the driveshaft.
Old 02-09-2005, 11:51 AM
ttyson's Avatar
you know come to think about it i had my trans rebuilt about a year ago and the shop didnt bolt the passenger side tunnel brace tight enough and the damn bolt fell off while i was driving!
maybe another bolt has come loose
bastards
Old 02-10-2005, 09:18 AM
ttyson's Avatar
is it ok to just remove the tunnel brace altogether and run without one?
Old 02-10-2005, 11:30 AM
qwk93ta's Avatar
I did in my 93 TA for 2 years.
Old 02-10-2005, 11:47 AM
tim99ws6's Avatar
Mine's been gone for years too......all you need is the transmission crossbrace down there......as long as you have a good set of DD subframes
Old 02-10-2005, 11:48 AM
ttyson's Avatar
mine is totally bone-stock
will it be alright or is my trans going to fall out lol
Old 02-10-2005, 12:20 PM
hourang's Avatar
sounds like the ds hitting the ypipe to me. easy visual check.
Old 02-28-2005, 11:04 AM
ttyson's Avatar
i installed my catback today and there was no damage on the driveshaft from rubbing or anything else. it looked damn near brand new
so now i am thinking maybe it is something in the cats rattling around?
Old 03-01-2005, 08:26 AM
ttyson's Avatar
to the top please
Old 03-01-2005, 02:52 PM
ttyson's Avatar
anyone?
Quick Reply: Metal-dragging-on-concrete sound when accelerating
