Think i'll need a 28in tire?
My previous run i ran a 12.2 at 114.
This is a T56 w/ 4.10's.
26x10.5x16 ET Streets
I never looked down at the RPM's but was well into 4th gear. I'll now be on a bigger cam w/ spray.
Will I need to get 28in tires to compensate? I'd rather get advice now, before i go out and bounce off the rev limiter
10 & 11 Second Club
Since adding the Vortech I have a hard time gettting traction with a 26" Hoosier which used to cut 1.45 60's with na. You`ll probably have traction issues also w/ 26" slicks, use the 28" for better traction + gearing.
