What's your experience with VC spacers
I am needing a set and not sure what the differences are between TR, More's, B&B, TrickFlow, etc.
Which ones do you have? How did they work for you? Any oil leaks? Easy to place on the head and stays put while you put the valve cover on? Get enough clearance for shaft rockers?
From what I can tell the new More Performance, Inc ones have a lip on the bottom that keeps it in place and prevents oil leaks. But I am not sure if that is worth the extra dollars when you can get them cheaper at Summit.
I'm not sure what the main differences are but I know Scroggin Dickey sells a nice set. What kind of Shaft Mounts are you trying to do? If you have a grinder you can fit a set of Jesel SS rockers underneath the covers.
Personally for the price of a lot of Valve Cover spacers you can get a nice set of new Valve Covers.
