Which maf for custom tune?
I'm getting close to getting my car put back together and was wondering which MAF does everyone use after a heads cam install w/ custom tuning? I have the stock MAF. Should i just get ported ends or go w/ the 85mm SLP? Also, will the 85mm Slp MAF work well w/ a custom tune?
TIA
Rob
TIA
Rob
Moderator
If you haven't spent the money yet, the best way to go
is the Z06 MAF (which you can get for less than the SLP
by a fair bit of yardage). It would be cleanest to get a
Casper's harness and use the 85mm's in-MAF IAT sensor.
The SLP harness doesn't. The Z06 MAF has a known cal
table while the SLP is a hack-job trying to use the stock
one (but, in my logging, it appeared to flatline at 10kHz
while MAP*RPM kept rising).
Though, descreening (and -not- porting, and -not- putting
aftermarket ends) the stocker would cost you nothing, in
cash, and nothing much in power relative to an 85mm. I
expect you could find at least one better place to put your
mod money.
mod money.
