oil drain back lines from heads....pics
Old 02-11-2005, 02:05 PM
2001CamaroGuy's Avatar
Default oil drain back lines from heads....pics
well I did what every road racer dreams of......set my heads up for oil return lines to deal with high RPM oil loading in the valve covers.....
I drilled three holes (in each head) and taped them for 1/4" pipe (1/4" pipe to 6-AN line), machined a path along the edge, and prevented most of the oil from going back down the stock way (which includes over the crank).......the lines run down and "Y" into a 10AN block (the 3 6s to a 10) and run back into the pan above the oil level....
https://ls1tech.com/forums/showp...426&postcount=3
Old 02-11-2005, 02:15 PM
jd13's Avatar
Sounds interesting, but your link isn't working.
Old 02-11-2005, 04:41 PM
jrp
SN95 Director
jrp's Avatar
he copied the url wrong
https://ls1tech.com/forums/showpost....26&postcount=3
Quick Reply: oil drain back lines from heads....pics
