Question on Strange 12 bolt install w/3 channel
Hi,
Need some help from people who have installed a 3-channel Strange 12-bolt.
The stock ABS sensor/module which screws on the top of the pumpkin does not fit on the Strange 12-bolt. The Strange appears to have it's own module with one black and one white wire sticking out. Do I just splice the wires from Strange to the existing wires or is this the wrong 12 bolt?
Originally Posted by DrkPhx
Hi,
Originally Posted by chief455
and which colors did you put together?
There are only two; white and black for both the Strange sensor and the OEM sensor. You have to remove the pigtail which connects to the panel on the frame and to to the OEM sensor. Cut off the sensor end that connects to the stock 10 bolt. Then splice the two wires (black and white) to the Strange sensor (black and white also). I soldered mine and wrapped them good. When you are ready to install, just plug the pigtail back into the panel bolted to the frame. Hope this helps.
I see different replacement sensors on the parts websites. I'll call Strange and get the part number from them to buy a spare
