SLP 402 short block questions
Old 02-12-2005, 04:37 PM
MakoLS1's Avatar
Default SLP 402 short block questions
"ZL-402" LS1 Short Block (High Compression)
Im looking at this stroker short block, i think my heads and a cutom cam would be great for this motor. Will stock LS1 heads bolt up to it? How about the stock oil pan and timeing chain covers and all? It looks like a awsome deal.
Old 02-12-2005, 04:49 PM
BlueSix's Avatar
I haven't heard too much about the SLP 402 kit....so i won't comment on its quality.
But all your parts will bolt up considering it's just a 6.0 iron block which is the same as your 5.7 alum block....just with a bigger bore and iron instead of aluminum.
Old 02-12-2005, 06:46 PM
01_SuperSlow's Avatar
SLP's ZL-402 is an aluminum block, not iron .
Old 02-12-2005, 06:50 PM
jrp
SN95 Director
jrp's Avatar
only if you use an ls2 block.
Old 02-12-2005, 07:06 PM
777's Avatar
which means no knock sensor's
Old 02-12-2005, 07:08 PM
jrp
SN95 Director
jrp's Avatar
SDPC is working on that, they got KS to work on the engine dyno but i dont think mounting while in a car was finalized.
Old 02-12-2005, 07:15 PM
777's Avatar
really, that is news to me...props to them...maybe i'll go with a 408 instead of the 347 if i can afford it...prolly not though...i'm just dreaming
Old 02-12-2005, 07:17 PM
jrp
SN95 Director
jrp's Avatar
ya, happened a few days ago, can pick up the saga in there thread in the ls2 section.
decisions decisions
Old 02-12-2005, 10:11 PM
fastsspr's Avatar
01_SuperSlow]SLP's ZL-402 is an aluminum block, not iron
But the one from SLP is build in an iron block.
Old 02-12-2005, 10:37 PM
Yes, that is a LS2 block
I think they used to have an iron ZL-402. Currently they are using aluminum blocks according to this.
http://www.slponline.com/view_product.asp?P=12412
Old 02-12-2005, 10:43 PM
jrp
SN95 Director
jrp's Avatar
yes, but the thread starter said "ZL-402" LS1 Short Block (High Compression)"
Crate-Engine Assembly, "ZL-402" LS1 Short Block (High Compression)
With GM’s versatile "Gen III" small-block gaining popularity as the foundation for a wide range of high-performance engine build-ups, market demand for an affordable LS1 stroker package has become increasingly intense. In response, SLP Performance Parts has devised a revolutionary new Gen III stroker short-block assembly, one that offers unexcelled performance and durability at a truly accessible price.
Dubbed the "ZL-402" to reflect its beastly 402-cubic-inch displacement, the package is chockablock with such race-proven hardware as a new GM LQ9 block, a 4.00" forged steel crank, and 4.00" forged aluminum pistons. With the right cam and heads and a properly tuned PCM, the ZL-402 is fully capable of producing over 575 hp and a similar amount of torque in naturally aspirated form.
This package is sold only in short-block form, minus manifolds, camshaft, oil pump, and other ancillary equipment. The obvious advantage of this approach is that it allows each customer to formulate a parts combination that is perfectly suited to his or her needs. (For those who prefer "one-stop shopping," SLP offers a host of uninstalled options on an à la carte basis.)
Although designed primarily for use in late-model F-Bodies and Corvettes, the ZL-402 also makes a superlative choice for most street-rod, muscle-car, and truck applications. Best of all, it’s sold outright, eliminating the shipping hassles, protracted vehicle downtime, and additional out-of-pocket expenses associated with core returns.
http://www.slponline.com/view_product.asp?P=12400
Old 02-13-2005, 01:28 AM
oooohhhh, I see.
My bad
