420 Bosch vs 340 Walbro
I was told yes..................... I know speed inc has takena single Bousch 420L to 720rwhp........ ive never seen a single 340 over mid 500's....... Ill be running dual 420L's in my new turbo setup.
Shooting for 800rwhp on a Mustang dyno.... should get it no prob.
Kyle
Kyle
Coal Mining Director
In theory, the last pump see all of the pressure. Roughly, you could say the 420 will be pumping against the 58psi and see what it pumps at that pressure....then look at the walbro curve at say 20psi and see what that rate is...and compare.
It would be nice to see a 420 flow curve vs pressure at 12.5v and at 16v...then we could really make a projection. A boost a pump on a 340/420 combo would be a powerful combo.
LS1TECH Sponsor
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Originally Posted by Racetronix
BTW, I love the Racetronix intank...keep up the good work
Thanks in advance
LS1TECH Sponsor
Originally Posted by kcshaner
I don't belong to the site, is there a chance you could share the resul ts with us? I would like to see if I have done something bad for my fuel system and if I should make some changes to it. IF you would reply via a PM that would be appreciated as well. Also, does Racetronix sell an boost a pump or equivilent? Do you think that would be a wise investment?
Thanks in advance
Thanks in advance
Simply install the extra connector set supplied with your Racetronix system and plug the booster into the Racetronix harness. It looks something like this : http://www.racetronix.com/product/RX...FPWHG-2-PB.jpg
__________________
>WEB SITE<
>WEB SITE<
For FI applications the MSD pump booster is the best choice as it has MAP based pump voltage. Thunder Racing carries them here: http://www.thunderracing.com/catalog...5&sid=259#P690
