Track results with MS3 and AFR 205's
Old 02-13-2005, 03:54 AM
Drew778's Avatar
Default Track results with TSP MS3 and AFR 205's
first run on street tires
2.431 9.175 87.39 13.641 110.77
2nd run still on street tire with a little smoke show
2.831 11.421 77.68 16.165 106.65
3rd with ET streets
1.768 7.672 91.48 12.024 112.82
4th
1.819 7.730 91.82 12.071 112.51
5th
1.713 7.582 92.06 11.916 113.13
6th
1.731 7.605 92.01 11.939 113.06
7th with a NX 50 shot
1.676 7.343 95.12 11.502 118.45
8th again with a 50 shot
1.644 7.321 95.33 11.476 118.44
the new motor only has 300 miles on it and we're still working on the tune (23* of spark and shifting at 6200 rpms), I hope its got more in it
Old 02-13-2005, 04:16 AM
gnx7's Avatar
Are the AFR's 66cc (unmilled)?
What does your car weigh?
Did you lock up your torqueconvertor?
Is this with an LS6 intake and ported stock TB?
MPH seems a little low. What altitude? I assume near sea level.
-Mark
Old 02-13-2005, 04:17 AM
Restricted User
CAT3's Avatar
I think I will be able to tune it like last time when I get home. Definately should have more in it. Your 60's suck bad. DA was probably up there too. But I bet your timing and fueling is fucked, probably seeing KR throwing you into Low Octane mode and just all sorts of screwy ****. I dont think your car likes anyone else tuning it
Old 02-13-2005, 04:21 AM
goober35's Avatar
Damn shifting at 6200 with a cam that needs to shift at 6800-7000k.
Your 60's blow. What does your car weigh/gears.
Faster than my old set up though. Nice times for not even have a desent tune on the thing.
Old 02-13-2005, 04:24 AM
Drew778's Avatar
-Mark
Yes, 66cc unmilled.
I'm not really sure about the cars weight, with me maybe around 3500-3600 lbs
I'm not sure about the converter?
Yes, stock LS-6 intake, stock Shaner S-2 TB
Yes, right around sea level.
I added that the tune has 23* of spark and shifting at 6200, maybe shift at 6500-6600 will help a little?
Old 02-13-2005, 04:28 AM
Drew778's Avatar
That must be it, better hurry back then
I still have the stock 10 bolt and 3:23 gears
I hoping it just needs more mile to break in
Old 02-13-2005, 04:53 AM
Restricted User
CAT3's Avatar
DA for Hawaii is NEVER at 0 or -, the humidity and baro makes it normally +800 or even higher ( in this case I would assume higher with the recent storm activity).
You edited your post damn it.
Shift at 6200, your not stock anymore lil bro, spin that ****** to 7000, let her breath and sing! If you want to run NA, get some timing in there and drop a touch of fuel, basically make this tune for your Nitrous runs, and modify a tune for NA. Stop trying to run both on one tune, you either run like you are now = Pat, or you blow holes in your pistons like the reason you got he bottom end replaced to begin with!
Stop putzing around. Gears, yep you need them, your crossing the traps at like 5700rpms, bottom of the power all the way down track. And if your still getting that bullshit MAP sensor code yes your converter is locked up, not good.
Old 02-13-2005, 04:54 AM
goober35's Avatar
LOL swap those gears to 373 and it will help a lot on the track. I have the same gears. I cut a best of 1.67 N/A with those gears.
Old 02-13-2005, 05:04 AM
Drew778's Avatar
Yes, that P-106 is pissing me off
Shift points 7000 and spark at 40* gotcha
Old 02-13-2005, 05:05 AM
Drew778's Avatar
I was told by Trevor at TSP if I plan to spray over a 150 shot keep the stock gears
Old 02-13-2005, 05:16 AM
Restricted User
CAT3's Avatar
Shift points raise them, and rev limited even more! I would stick to around 28* of timing.
The P106 needs to go away!
Old 02-13-2005, 05:27 AM
goober35's Avatar
I would go to a 373 and a 28in tall tire it would be a small increase in gear with the tire 28. The 28s would take the 373 and make them seam like 355.
Old 02-13-2005, 06:53 PM
Drew778's Avatar
I don't trust the stock 10 bolts enough to try
Old 02-13-2005, 07:43 PM
Lady Redhawk's Avatar
Location: sojourning....looking for my city whose builder and maker is God.
Do you have tuning? Why hasn't that been tuned out. Not hard there are tables for that.
Old 02-13-2005, 07:59 PM
Drew778's Avatar
I thought we had it done, Jason from TSP sent me two tunes and said he took care of it
Any help would be great
Old 02-13-2005, 08:10 PM
hummm. are you sure you don't have an vacuum leak? Also, it isn't hard to damage the MAP sensor itself.
Old 02-13-2005, 09:26 PM
Drew778's Avatar
A friend and I have been playing with Jason's tune and have got the surging and bucking a little better, I think it in the tune
Old 02-13-2005, 09:35 PM
Jason is good! Hard to tune long distance though.
Old 02-13-2005, 11:43 PM
Drew778's Avatar
I agree
Old 02-18-2005, 04:10 PM
mike c.'s Avatar
i would of thought with the afr's it would be faster. i was near mid 11's with an old set of speed inc heads.
Quick Reply: Track results with MS3 and AFR 205's
