Drag Racing Tech
Finished up the wheelwells for the 28x10.5x15W tires...
Old 02-13-2005, 08:21 AM
Fireball's Avatar
Talking Finished up the wheelwells for the 28x10.5x15W tires...
My friend who's one helluva welder (who did my rollbar) came over and we worked on finishing up the wheelwells.
This is what a stock wheelwell looks like (in the front area)
That poor wheelwell didn't know what was coming
First, I had cut away areas that hindered me from putting the tire on the car(which I previously posted)
https://ls1tech.com/forums/drag-racing-tech/272479-wheelwell-cut-28x10-5w-tire.html
Though this worked, it left areas that were still relatively close to the side of tire. If you took a turn too hard (at the return road), he was worried it would rub. So...we cut into the wheelwell, and beat it into the car
We then fabbed up some patch panels out of 22 ga steel sheet (similar size to what was in the car) and started mig welding them in place
Also cut out the whole area where the bumpstop was and reinforce the two areas with some 1/8" thick steel sheet. Sprayed on some undercoating and finished them up
Old 02-13-2005, 11:21 AM
WhtLT1's Avatar
Looks good
Old 02-13-2005, 12:00 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
nice!
Old 02-13-2005, 12:59 PM
A3Z28's Avatar
pics fo the car with the tires on it?
Old 02-13-2005, 01:09 PM
2FAST4U's Avatar
Wait that is it that is all it takes? What does it look like with the tires. I will have to do that!
Old 02-13-2005, 01:57 PM
Fireball's Avatar
Taken during the fitment process...
Old 02-13-2005, 03:39 PM
Motorboater
SilverGhost's Avatar
looking good
Old 02-13-2005, 05:54 PM
A3Z28's Avatar
very nice...i'll have to print those pics and get to work...very nice
Old 02-13-2005, 07:27 PM
Squintz Palladoris's Avatar
Very nice. I took a sawzall to mine. There is still a little more that I need to remove to step up to a W tho.
Brad
Old 02-13-2005, 07:33 PM
GueSS Who's Avatar
Those tires will hook like mad
1.27 60ft here with the W tire.
Old 02-13-2005, 08:14 PM
2000WhiteTA's Avatar
Looks good
Old 02-14-2005, 12:02 AM
JS
JS's Avatar
Looks great Brian...
Old 02-14-2005, 05:53 AM
Fireball's Avatar
I'd do backflips if I can find a 1.39
Old 02-14-2005, 05:54 AM
Fireball's Avatar
one other comment...that stock coating is some seriously tough ****....took alot of work just to make it disappear in the areas we were welding
Old 02-14-2005, 06:12 AM
tektrans's Avatar
Looks good. What offset are your rims and are you concerned it will rub on the outer fender in the front. That's where mine were rubbing.
Old 02-14-2005, 06:14 AM
smokinHawk's Avatar
so this is a legal modification for not putting any mini tubs on for the stock classes?
did you have to midify the fender lip at all or did the tire fit in there with out modifying it?
Old 02-14-2005, 06:19 AM
Fireball's Avatar
mine look to have >1" of clearance. MT says up to 1.5" of growth which would be 0.75" per side. its close but should be ok.
Old 02-14-2005, 06:23 AM
Fireball's Avatar
general rules say this:
Mini-tubs are allowed. Rear frame notching for tire clearance permitted
They fit without modifying the fender lip, but I beat the front area to keep it form rubbing when the tires grow.
Old 02-15-2005, 12:09 PM
tektrans's Avatar
I don't know man, sounds like you're assuming that .75" growth will be equal front to back during the whole run. Now someone please correct me if I'm wrong but during hard acceleration with a wrinkle wall tire most of the growth would be towards the front of the tire (think about how the tire looks during launch) maybe growth during launch is the wrong word but the front part of the tire will be forced foward. And during decceleration the back of the tire would project back more than the front. The most "equal" growth would be duing the middle of the run.
I have a Trans Am also and with those same tires they rubbed "ALOT" front and back. I'm just sayin' cause I saw what it did to my outer fenders and how much rubber it took off those tires on just one single run.
Just be carefull Fireball, I've seen you drive.
Old 02-15-2005, 07:37 PM
SMOKIN01TA's Avatar
maby ill just order a 6.5 backspace for those
looks good tho.
