I've searched!! What cam for me?
Here is a list of current mods:
-SSF3500
-lid
-24,000 Tranny cooler
Mods sitting in my room:
-kooks headers/ORY
-LS6 intake
Mods ordering in two weeks:
-LS6 oil pump
-timing chain
-Ported LS6 heads
-Comp Cams grind
Alright, now which comp grind should I get(i am ordering a package and they will do any custom grind)? I have stock 3.23 gears and I will be tuning with HPtuners. I do not want to flycut since I will be doing the install myself. I would like to go with a bigger cam and I would like a cam that has proven itself. The car will be mostly a street car and will see the track maybe twice a year. I am looking for something in the 230-240 range.
Thanks
-SSF3500
-lid
-kooks headers/ORY
-LS6 intake
-LS6 oil pump
-timing chain
-Ported LS6 heads
-Comp Cams grind
Thanks
Forcefed is setting me up with the package. Brad suggests the 232/238 595/585 112 LSA cam. The only reason that I hesitate with this cam is due to the fact that they are the only ones I can find that are running it. They call it the annihilator cam. They are running it on 110 octane with a 110 LSA and open headers. I am just looking for something that has proven itself(on more than one car).
I started a thread the other day to see if anyone has any input on this can and there arent any replies. Anyone have any other custom comp grind cams?
if the heads arent milled...and it has stock LS6 valve sizes, i'd go with the TSP 233/239 or torquer (233/233)
i have a 3500 stall and 233/239 it drives great the power is definitly there.....matched up with a set of good flowing heads you'll see some excellent numbers
Are those comp grind cams??
Originally Posted by tim99ws6
Are the heads milled? If so, how much? You interested in nitrous/forced induction, or just N/A?
Oops, they can be milled if I want them to. Here are the specs
FFHP Stage 2 5.3L Heads
Fully CNC'd
Hand Finished
Bronze Guides
Larger Valve Seats
REV 2.02 Intake Valves
REV 1.57 Exhaust Valves
Patriot Dual Gold Springs
Titanium Retainers
Hardened Spring Seats
Super 7 Locks
Viton Valve Seals
Custom 3 Angle Valve Job
Milled if desired
They will be upgraded to the LS6 heads too!
i know you are limiting yourself to comp grinds. but, take a look a the vinci 060 grind http://www.vincihighperformance.com/...%20LS1%202.htm
