Drag Racing Tech
How fast do you have to run before you have to have dash bar?
Old 02-14-2005, 09:08 AM
c5ls1vette's Avatar
Default How fast do you have to run before you have to have dash bar?
When do you have to have the dash bar (the one that runs under the dash from driver side to passenger side).
thanks, Brandon
Old 02-14-2005, 09:15 AM
Big Mike's Avatar
I have a full 10pt cage without the dash bar and I'm cert'd to 7.50. I think the dash bar is optional. Someone correct me if I'm wrong.
Old 02-14-2005, 09:21 AM
LS1Tech Sponsor
MADMAN's Avatar
The rules state that you need the dash bar if the floor and firewall has been cut more than 24 square inches. Now I install a dash bar in all the cages I build just for strength.
__________________
www.madmanandcoracing.com
225-343-9029
Old 02-14-2005, 10:17 AM
c5ls1vette's Avatar
thanks, I might as well go ahead and put it in while I have got the dash out.
Old 02-14-2005, 10:38 AM
Big Mike's Avatar
Cool, thank you for the clarification.
Old 02-14-2005, 12:22 PM
BTL FED's Avatar
How do you get a 10pt cert to 7.50, I thought a 10 point was good till 8.50 and below that you had to have a 25.5 cert cage?
Old 02-14-2005, 01:11 PM
Louis's Avatar
Harlans car is a 10 point, and its cert till 7.50 because he got it certified before the rule went into effect.
All you need for a 7.50 and slower is the funny car cage, correct?
Old 02-14-2005, 01:52 PM
LS1Tech Sponsor
MADMAN's Avatar
Louis the new cert is 25.5 for full frame cars. This will get you a sticker to 7.50. You need X bars in both doors. Funny car cage , rocker bars and x bars under your seat. The easiest way to explain is to buy the SFi book.
__________________
225-343-9029
Old 02-14-2005, 03:01 PM
Big Mike's Avatar
Exactly! I was "grandfathered" in before the new ruls came into effect.
Old 02-14-2005, 06:01 PM
Stu'sWS6's Avatar
I don't think that is the case-I think your cage is only good to 8.50 this year-even though your sticker says 7.50. Pretty sure Madman is right here-25.5 cert. required past 8.50.
Old 02-14-2005, 07:13 PM
LS1Tech Sponsor
MADMAN's Avatar
according to my chassis inspector the sticker on the car is good till it expires. Then you will be subject to the SFi certifications.
__________________
225-343-9029
Old 02-14-2005, 08:10 PM
Stu'sWS6's Avatar
News to me, good info
Old 02-14-2005, 08:17 PM
Big Mike's Avatar
My pink receipt that the NHRA inspector gave me says 7.50 on it.
Old 02-14-2005, 10:07 PM
Stu'sWS6's Avatar
I had heard that cert. to 7.50 cages from last year would only be good to 8.50 this year b/c of the rule changes. The tech guys at the track around here prob. wouldn't know the difference anyways
Old 02-15-2005, 02:26 PM
1fastWS6's Avatar
I've also been told that whatever cert. you have is good until it expires. Then it's subject to the newer rules.
Old 02-20-2005, 12:59 PM
leaftye's Avatar
A little off topic, but the new Z06 has a dash bar. Does the stock unit meet the cert specs, or does a new one still have to be installed/connected to the cage?
Old 02-20-2005, 01:10 PM
A3Z28's Avatar
MADMAN, where can you get the SFI book from? and could you PM me a price on your 10pt cage with dash bar and rocker bars. i want be legal to ATLEAST 8.50s but safer is always better. i would probably go ahead and bring it to your shop for the install so it could get cert'ed there. thanks for any info.
Old 02-20-2005, 01:54 PM
Dan / Wolfe Race Craft's Avatar
They may be grandfathered in but remember with a cage that was stickered last year to 7.50(if not 25.5), you cannot legally exceed 180mph even if you are above 7.50. IF you exceed 180mph between 7.50 and 8.49 then you must be 25.5.
You can purchase the SFI spec directly from SFI. Do a search on google for SFI Foundation. The Specs are $35.00 for the 25.5.
Dan
