Yet another heads and cam Dilema!!!
Old 02-15-2005, 08:03 AM
MyniceSS's Avatar
Default Yet another heads and cam Dilema!!!
I've done tons of searching and reading, but instead of lurking I'll post my questions. The car is a 2000 M6 SS, the planned mods are Kooks LT, ORY, Hooker Catback, ASP UD, MTI Lid. I've somewhat narrowed it down to a few candidates for cams..... MS3, TSP 233/239, G5x3, all on 112 LSA. SInce these are all pretty aggressive street cams, what heads would on average allow me to clear my goal of breaking 450 with still an awesome amount of torqueand yet still not breaking the bank. I've heard awesome things of AFR 's TEA's and Patriots. The car still has the stock LS1 manifold, and the FAST is just way too pricey, but if I can find an LS6 manifold for a good price I'll bolt it on while I'm already in there. AFR's are putting down awesome number, but like many others said that's with high dollar supporting boltons. ANy inputs, opinions and or advice would be greatly appreciated.
Old 02-15-2005, 08:16 AM
MNR-0's Avatar
A cheaper option would be a set of 6.0L heads with either some chamber work or milling to increase the CR. Same ports as LS6.
Old 02-15-2005, 10:21 AM
matts22's Avatar
Check into FMS cams as well. Many people are getting a lot of power and amazing drivability with them.
Old 02-15-2005, 10:23 AM
BrentB@TEA's Avatar
I would use our 5.3 heads with a larger intake valve (2.055 with new intake seats or a 2.055 cut down to a 2.04 for use with the stock intake seats.) At least an ls6 intake is needed as well as a cutout,ported TB and under drive pulley to make the numbers your wanting to make.
Thanks for keeping us safe.
Brent
Old 02-15-2005, 10:45 AM
93Polo's Avatar
I'm running a set of regular with no hand finish work TEA stg2 5.3s 2.02 intake valves decked .010 just for clean up, Futral F11 228/230 112+4, CamminBeaSSt ported TB and Kooks 1 3/4 on my C5. The setup turned 436rwhp/415rwtq on stock 65k mile LS1 short block with out a cut out.
A Futral F13 or F14 and set of TEA heads should have no problem getting your 450 rwhp and a strong tq curve.
Old 02-15-2005, 08:16 PM
MyniceSS's Avatar
Thanks guys for all the input. Just to add a little more comments, the ls1 shortblock currently has 63k. The install will be done by myself with the help of a few other knowledgable friends. I checked out TEA's prices and they aren't bad either. Does anyone know where I can get an ls6 manifold for a good price(cheap)? And as far as tuning goes, is it possible for me to tune it somewhat temp with a plugin type system like predator or vinici?
Old 02-15-2005, 08:21 PM
MyniceSS's Avatar
Well if I go TEA then it looks like I'll be getting your exact heads. I'll also be going with KOOKS 1 3/4. Like many others I've heard nothing but good things about the F13, but just out of curiousity the specs seem just a tad bit smaller than TSP's 233/239 cam, just comparing specs wouldn't the TSP's cam, put out better peak with a similar torque curve of the F13?
Old 02-15-2005, 08:26 PM
MyniceSS's Avatar
Brent
Ok you just lost me a bit. Are you saying to purchase your "off the shelf" heads and then upgrading the valvetrain components? I won't be getting a cutout, but I am considering getting an LS6 intake, TB ann an underdrive pulley. I was looking at your Stg2 5.3 heads, and matching them with a F13 or TSP 233/239 cam. What do you think?
It's my pleasure to be apart of history defending our freedom.
Kamar
Old 02-15-2005, 08:51 PM
matts22's Avatar
Kamar
They assemble them for you, so you can use whatever springs, valves, retainers, etc. that you want.
Old 02-15-2005, 09:41 PM
pdd
pdd's Avatar
Thats what im shootin for
Old 02-15-2005, 09:52 PM
matts22's Avatar
Oh come on, you know you want 500.
Old 02-16-2005, 08:08 AM
MyniceSS's Avatar
Now just out of curiousity I've seen a few guys on here posting dyno graphs of cars getting 470+ rwhp, mainly AFR. Now I know they are using just about everything I have except for the fast 90 90 setup, is the fast manifolds worth there price for the power they put out? Plus AFR's are pricey compared to other well known companies such as TEA and Texas speed. Should they be capable of putting down similar numbers compared to afr?
Old 02-16-2005, 08:33 AM
NO5.0's Avatar
MyniceSS, when are you planning the mods? I will have an ls6 intake you may want as soon as my parts are available.
Old 02-16-2005, 08:41 AM
BrentB@TEA's Avatar
Kamar
No we do each and every order per each customers specs. We build them to your specs here before they ship. I think you will find the cutout will be one of the best gains per buck spent. I think either combination would work very well. Brent
Old 02-16-2005, 09:26 PM
MyniceSS's Avatar
Default Ls6
I plan on doing the mods at the end of the month or the beginning of next month. How much would you sell it for?
Old 02-17-2005, 11:45 PM
MyniceSS's Avatar
Well before I start to modify my car, I figured no matter what the car made after my planned mods, it'd be useless without some form of baseline numbers. So I went to South Georgia Corvette, and linked up with Aaron, who's really cool, not to mention there were a few sick rides there. The car is a 2000 SS that is mechanically stock, the only mods that have been done to the car is just, shocks, springs and swaybars. So I wouldn't be dissappointed, I made a personal guess that it should put down at least 290-295, but I'd be happy if it made 298-303, and as for torque, I made a guess at 310-320. Lets just say I'm pretty stoked for putting down the numbers I did with two back to back runs. Now let the modding begin.
Old 02-17-2005, 11:46 PM
MyniceSS's Avatar
It made 313.1wrhp and 331.1 wrtq
Old 02-17-2005, 11:55 PM
01_SuperSlow's Avatar
Nice numbers for being completely stock.
Old 02-18-2005, 08:47 AM
MyniceSS's Avatar
Thanks, now hopefully I can break 450wrhp, when I'm done.
