My friend swears reactime time affects your et. How can I prove him wrong?
Story:
I have a buddy of mine with 01 SS that waited 2.5 seconds (RT) because he wanted to make sure he gets a good launch after doing mods to the car. His ET was 11.8 in the 1/4 mile. My other friend (drives TT300zx) said if his reaction time was less than a second then he would have been high tens. He always do bracket racing on import events so I dont know if the rule varies between imports and domestics. Someone help me out here. I want to explain to him how this works. Thanks!
Originally Posted by iwantLS1
Story:
Thanks for the replies! So if doing a bracket racing, RT still wont affect ET. He will try it next time he is at the track. He's been on a lot of bracket racing so I was surprised to know that he didn't know about this.
EXPLANATION: Bracket racing combines RT AND ET to determine the winner/loser.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
That'd probably be a safe bet. Reaction time is just that: how well you react to the green light (or to be correct, the time between the 3rd amber and green light). If you react better to the green than your opponent and you both run the same et, you'll get to the finish line first. Take that rational and apply it to bracket racing and you can see where the RT factors in in helping determine winners and losers.
Derek
Derek
Bracket racing is 75% reaction time 25% dialing your car in. Wanna see some of the worst reaction times, go to an import event. they think a .200 light is good. I'm not happy unless I'm .040 or less.
7 Second Club
1 Post
"The Drag Racing Director"
Originally Posted by Villain281H
I disagree. Bracket racing is 50% reaction time, 40% dialing (not many people can sandbag effectively), and 10% luck
50% reaction time,20% dialing the car and 30% LUCK!!!!!!!
The last one is the most important of all!
Coach
7 Second Club
1 Post
Originally Posted by Coach 02 A3 Z/28
Maybe it should look like this;
Coach
Coach
Derek
Yes, RT can effect ET, its all in the staging.
Depending on your staging technique, deep vs. shallow,
this could amount to several hundreds of a second.
A shallow stage gives you a longer rollout thereby giving you
more of a running start(quicker ET) but a worse RT. A deep stage eliminates
your running start(slower ET)but a better RT.
Emil "bracketcar" Dusek
yes but the staging is just that staging. reaction time does not effect e.t. no matter what you can sit there all day and cut the same time as if you ran a .00 if you staged the same both passes and even staging different is only going to affect a few thousandth of a second.
'Bird Director
