V6 Fbody springs vs V8 Springs is it worth the swap?
I am going to install a 12bolt rearend soon and seen that the F body V6 springs are popular for drag racing for the LS1 F bodys. Like most others I drive it on the Street, I realize I have to give up some ride, but how much??
Does it really pay for 60s on the Track, and is there any tire rub out of the hole? I have all the BMR stuff except the Torque arm so far. Rest of my set up is in my sig.
Anything better than V6 springs out there??
Thanks,
Speedo
Thanks,
Speedo
Here is some specs
FRONT
22077189 (39 N/mm, 223 lbs/in) (93-97 V6)
22133438 (45 N/mm, 257 lbs/in) (98-00 V6)
22077197 (51 N/mm, 292 lbs/in) (93-00 V8)
22132887 (63 N/mm, 360 lb/in) (WS6, 1LE)
REAR
22077418 (16.9 N/mm, 95.4 lbs/in) (93-97 V6)
22077421 (19.9 N/mm, 114 lbs/in) (93-00 V8, 98-00 V6)
22132889 (23 to 30 N/mm, 130-170 lbs/in) (WS6, 1LE)
What is your car running now?
FRONT
REAR
Originally Posted by brandonppr
Here is some specs
FRONT
REAR
221328 z89 (23 to 30 N/mm, 130-170 lbs/in) (WS6, 1LE)
FRONT
REAR
Yes, this is great info since I was looking to buy springs out of an 96 F-body V6..
Thanks for the info......
I'm curious to know where those spring rates came from. From what I remember GM changed the front spring rate (softer) for the LS1's due to the lighter weight compared to the LT1.
I ruin the end of films...
I'd run factory springs in the back. A softer spring in the *** isn't the answer. Soft in front, stiff in back.
I'd like to know where the numbers posted came from too. I figured an iron block would have more than a 300# or so spring. I was thinking more like 315 or 325.
I have a WS6, so I have the super stiff springs. I swapped my rear springs for early V6 springs. I haven't been to the track with it yet, but I actually like the ride on the street better. Not quite as bone jarring. I can't tell that big a difference in handling.
back in '99 and 2000 at the US Nats in Indy..I questioned several of the stock eliminator boys about springs..they were running the stiffest available stock spring in the rear and the stock v-6 springs in the front...they agreed at that time.. that was the very best combo..even better than the trick springs that were available..
just my .02
Matt
just my .02
Matt
just my .02
Matt
just my .02
Matt
I am just curious why the softer in the front....weight transfer?
Daren
Scroll down 1 screen.
