Mess Up Abs????
Possible Scammer - Buyer Beware - Issues Unresolved
Mess Up Abs????
i am wantin to put Y2K vette wheels on my T/A. will 18/9.5 mess up my ABS??
i was told by one guy that they would but i wanted to post here to see what ya'll's answer would be
HEy Doug, from what I heard, you are wanting to use the 17"x8.5" wheels up front, & the 18"x9.5" wheels out back. You'd end up using tires that aren't the same diameter front to rear. Unless I'm mistaken, that will cause problems with the ABS.
I'm sure an f-body owner here will know for sure.
I'm sure an f-body here owner will know for sure.
Originally Posted by jimmyblue
From what I've seen, F-bodies start having ABS problems
at right about 10% tire circumference difference. Below
that I haven't seen any beefs; above it, a couple.
doug
Originally Posted by jonnyc
i had 275/40/18 on the back and 275/35 18 on front for about three years and never had any problem.the rears were probably 1/2 inch taller.
so if the tires = out to the same circumfrance the ABS will work fine?
if you run 17 and 18,you'll probably want to go with what the vettes use.295/35/18 rear and 265or275/40/17 front.you should be able to fit a 295 on a 9.5 wheel.i use to run 285s on a 17x9 wheel.
