Spraying thru a powershift?
is anyone doing this i was thinking about in but not sure yet. i just read about the new accel nitrous programer that will shut the spray off 50 rpm before the rev limiter but will this system work with my car, to my understanding (which i am probably wrong) there is no simple ignition box, or is there?
thanks
jmac
thanks
jmac
I do it. A standard window switch works fine for me. I have an older Mallory window switch. I set my PCMs rev limiter high (like 7500 or so), shift light at 6900, and window switch to 7000 or so. Leaves me plenty of room. I'd MUCH rather have more room up top (500 RPMs) so that I don't hit the stock rev limiter (which cuts fuel). 50 RPM to me would be too close. More like 200-300 minimum.
