Generation III External Engine - new exhaust, pics!
blind527
02-16-2005, 06:09 PM
that is my new exhaust system, the only thing i need to do is center the pipes correctly. i think the left side needs to be banged in a little more then i'm done, the left side hangs a little crooked, and the muffler is a little slated down, is there a way to change that?click here (http://groups.msn.com/_Secure/0SAACA*8TK6qgnbAhaikdo8ukGl5ExuKT1amQSvSz62NeTisA6 0!GWThyJcNZNtPpaujd20ZzDQYEKOedqsQdkmTA4EZq7to05Dc Tt30zlqJGAAAAynJ6Ag/02-16-05_1715.jpg?dc=4675510422276681557)
blind527
02-16-2005, 10:32 PM
come on guys, i know you can help me :\
Cummins
02-16-2005, 11:49 PM
looks like you just have to move the pipes to the right a little bit and then your good :)
blind527
02-16-2005, 11:51 PM
i tried man :-\
the left pipe doesn't seem like it's in all the way though, i have tried SO hard to get that thing in! the right side hangs PERFECTLY, but the left side hangs a little crooked. the muffler also slants down a little bit, but it is all VERY solid. should i have a shop look at this, or just pound the left tube in with a rubber mallet till it gives?
Davd901
02-16-2005, 11:57 PM
You said new exhaust system; if an exhast shop installed this, they shoud fix it and make it right.
blind527
02-17-2005, 12:02 AM
i got it used, i set it up..
a shop tried telling me it would be 200 bucks to put on a cat back system clamping it..i was like uh i dont' think so.
GuitsBoy
02-17-2005, 09:02 AM
Can you just shorten the pipe that leads to the muffler's input by an inch or two to move it over?
blind527
02-17-2005, 09:56 AM
i guess i can try that, but i don't have a straight cutting sawzall or anything like that. isn't there a way to really get it in there? i mean i got all my pipes in there, i had troubles with the over axle pipe, but loaded that sucker with wd-40 and slide right in. which side looks betterly positioned, the left or right? the right side is clamped where it's supposed to be, and positioned where it's supposed to be IMHO, i think it's just a matter of getting the left pipe in more so it can hang straight. anyone have any thoughts on how to get it in?
2001 White Ws6
02-17-2005, 09:59 AM
Have you tried loosening all the connections and just practice fit them to get the right look on the tailpipes?
Bang the left pipe till it gives...maybe put some lube on the connections of that one and then bang it into place.
blind527
02-17-2005, 10:01 AM
i was never able to get the left one on all the way in the first place, the over axle pipe and the right pipe were already attached to the muffler ;) i tried putting wd-40 over the left side, but it only goes to a certain point then it stops. the rubber mallet i have isn't in the greatest condition either ;)
GuitsBoy
02-17-2005, 10:02 AM
Well, you can try and expand the muffler's input using a pipe exxpander available for free rental at autozone. You may be able to wiggle it in a little further. Also, you could notch an inch or two down the pipe leading into the mufflers input that will let the pipe compress just a hair and hopefully slide further in. Or you could just cut the pipe with a hack saw, ir an angle grinder, both of which can be found cheap at any bigbox hardware store. An angle grinder with a 4.5" x 3/32" metal cutoff wheel is an invaluable tool to have around.
2001 White Ws6
02-17-2005, 10:04 AM
What brand of Cat-back is it??
Quick 99
02-17-2005, 10:10 AM
yupper
blind527
02-17-2005, 10:13 AM
it's a 3" random tech cat back system.
kpowr82
02-17-2005, 11:57 AM
The problem is the last guy that had the setup on his car tightened the clamp to the point that the connection from the muffler actually bent around the tailpipe. Look at it and see if it's a little deformed. If it is, a pipe expander from autozone should help out. Notching the tailpipe with a dremel as mentioned above might also work.
blind527
02-17-2005, 12:28 PM
is it normal for the muffler to be straight but slanted a little bit? it's not perfectly flat like the stock one, and it's also a lot larger in size. since i haven't had the time, i'll just take it to a muffler shop after school on monday and see what they say.
LSUxBlake
02-17-2005, 12:46 PM
Hey, a good way to fix it......
You should have a rubber hanger connecting the right tailpipe to the factory position. Get a large radiator hose clamp (the type that you can use a screwdriver or socket on to close/open it, avail at Autozone / O'Reillys), put it around the rubber hanger, and tighten it up. It'll compress the hanger, therefore pulling your muffler and tailpipe up and making them level with the rest.
blind527
02-17-2005, 01:00 PM
so this is for the left one? the right one is in good positioning and clamped well.
the left side doesn't seem to go in all the way, so get it compressed and it will pull together? i will see this :D
LSUxBlake
02-17-2005, 01:25 PM
Did the job for mine. Hope it works out good for you too.
