Anyone know anything about lunati voodoo 227/233 cam?
I just saw this in the new summit catalog. Lunati voodoo hydraulic cam for small chevy specs 227/233 .489/.504, RPM range 1,800-6,200 for only $189.95. I got this from their website.
That sounds like EXACTLY the cam I'm looking for. Anyone know anything about it?
Lunati Voodoo Cam and Lifter Kits
Take your ride to the next dimension.
Unless you're a witch doctor, choosing the correct cam can be nightmare. These Voodoo cam and lifter kits by Lunati are the answer! The gurus at Lunati have taken cam design to another dimension with profiles never before utilized in cams. Only the world's best profiles are included in this line, making cam selection an easy choice. Voodoo incorporates 30 years of cam design experience with more recent developments in profiles, geometry, and tolerances to deliver the most aggressive ramp profiles ever used in hydraulic flat tappet cams. Asymmetrical lobe designs with slower closing sides set the valve down easy, to reduce noise and premature failure of the valvetrain. These cams deliver more "area under the curve", meaning more throttle response, quicker acceleration, more vacuum, and better efficiency, combined with maximum horsepower and torque. Matching lifters are included.
I'll have to do that. Man, that sucks that I overlooked that it was SBC. I guess I was too excited. That's pretty much the exact RPM range and duration I want.
