What gears does my car have?
Old 02-17-2005, 01:19 AM
Hot02SS's Avatar
Default What gears does my car have?
Do I have 2.73 or 3.23 gears?
Old 02-17-2005, 01:58 AM
That's what she said...
TheBlurLS1's Avatar
check out your RPO codes on the drivers-side door, might have to look up a listing somewhere of what all the codes mean. you can also jack the car up, rotate the tire one time, and count how many times the pinion spins.
example) tire spins once and pinion spins ALMOST 3 times... its a 2.73
example) tire spins once, and pinion spins a little more than 3 times... its a 3.23
i think all the SS cars have a 3.23, but i'm not for positive.
Old 02-18-2005, 02:29 AM
35th SS's Avatar
you have 3.23s in there.thats what came out of mine and switch to 3.73s.
Old 02-18-2005, 01:15 PM
Hot02SS's Avatar
Ok, I just wanted to make sure. I wanted to change them if they were 2.73 but Im fine with the 3.23. Now just gotta change to a 12 bolt...
Old 02-18-2005, 02:42 PM
GT Griller's Avatar
Well urs is an SS so it might be 3.42's. Go to ur driver side door and look for the codes that start with a G. GU5=3.23, GU63.42, GU2=2.73
Old 02-18-2005, 05:44 PM
00firebird's Avatar
all manuals came with 3.23's .. if you have an auto it could be 3.42's
Old 02-18-2005, 05:50 PM
00firebird's Avatar
also check the door for these codes...
GU4 AXLE REAR, 3.08 RATIO
GU5 AXLE REAR, 3.23 RATIO
GU6 AXLE REAR, 3.42 RATIO
Old 02-18-2005, 07:04 PM
glennhl's Avatar
Actually auto come with either 2.73 or 3.23. All manuals come with 3.42's.
Old 02-20-2005, 11:57 PM
TheBlurLS1's Avatar
no f-bodies (ls1 at least)came with the 3.08 ratio.
Old 02-21-2005, 12:26 AM
Hot02SS's Avatar
Hummm....Tommorow I will look on my door to se what gears my car has.
Old 02-21-2005, 12:50 AM
02WS6Bird's Avatar
you have an SS lol its got 3.23's
Old 02-21-2005, 02:10 AM
Smitty's Avatar
yup.....all M6's came with 3.42's.......all auto's with Z rated tires(16 or 17inch) 3.23's....rest of the auto's were 2.73's
Old 02-21-2005, 06:59 PM
Hot02SS's Avatar
Ok I looked on the door, and it had the GU5 Code. So it has 3.23 gears.
Old 02-21-2005, 09:35 PM
GT Griller's Avatar
Not true. 2.73's did not depend on ur tire rating or rim size. It was just what u got. 3.23's or 2.73's either was available for A4's. My friends 02 Z with Z rated tires rim size 16 it came with 2.73's.
Also F-bodies did come with 3.08's. Ur right LS1's didn't but in the V6 camaro's it was an option just like the 3.23's and 2.73's were for the V8's. 3.08's i think were for the M5's.
Old 02-21-2005, 09:37 PM
02WS6Bird's Avatar
Your right it didnt depend on the tire rating-the tire rating depended on the gear
