Comp 978's
Old 02-17-2005, 01:46 PM
DEEZ98Z's Avatar
Default Comp 978's
What lift are they good for?
Old 02-17-2005, 03:49 PM
Unaffliated Racing's Avatar
.600" if installed at 1.850"
Old 02-17-2005, 04:57 PM
DEEZ98Z's Avatar
Son of a! Now I will have to change them out.
Old 02-17-2005, 09:09 PM
98TAauto's Avatar
have fun focker
Old 02-17-2005, 09:54 PM
DEEZ98Z's Avatar
That would be Eric changing them out
Old 02-17-2005, 10:13 PM
98TAauto's Avatar
BWAHAHAHHA.....
why swap them? are you plannin on running over 600lift?
Old 02-17-2005, 10:49 PM
DEEZ98Z's Avatar
cam I have now is over .600
Old 02-17-2005, 10:59 PM
whitt1's Avatar
TEA installed 978s on my heads I forget what the installed height was ,but they said the springs were good for .650 lift.I'm running .605/.616 lift.
Old 02-17-2005, 11:28 PM
DEEZ98Z's Avatar
Thanks, I will have to look into that.
Old 02-18-2005, 07:05 AM
98TAauto's Avatar
thats what i thought also... i remember them telling me I wouldnt have to worry about lift on my cam untill i got well over .600 with their springs
my cam now is borderline... very borderline but I think they will hold me fine
Old 02-18-2005, 08:27 AM
Yeah they are good to .650" if you install them at 1.900" but, that only gives you 107#'s on the seat for spring pressure.
Old 02-18-2005, 10:08 AM
DBN
DBN's Avatar
Default Comp 978's
I just got a set of AFR/TEA heads that HAD 978's on them. TEA set them up after doing the port work, but when I checked the springs they were set up at 1.750. This means that my .600 lift cam would coil bind before it reached .600 lift. I also had 160# of seat pressure on a hydraulic roller cam. I had to get a new set of springs, retainers, locks, and locators that would work with my heads. The 978s are great springs, but I can't use them with my heads due to lack of installed height. They are for sale if anyone needs and can use them. If I were you, I would check the installed height of your springs.
Old 02-18-2005, 10:18 AM
DEEZ98Z's Avatar
I will be taking them to Tin Shed.... they will be taking care of all that for me.
Old 02-18-2005, 11:44 AM
koolrayz's Avatar
I bought a set of TEA heads from TIM@EAD with 978 springs He said they were set up for a .635 lift cam It turned out I had .025 till coil bind which meant they were set up to comp spec's of 1.850. SSOOO I also have a set of 978's for sale never used with the trimmings. They are great springs but not really for cams over .600 ask TEA they will tell you the same thing. Just dont ask that bullshit artist Tim@EAD
