brutal bumm rearend sound :(
Hi!
My rearend generate a loud sounds:
from 1 mph...
the sound is harder, and harder, the chassis shaking harder, and harder, when I accelerate(or roll (in Neutral), or turn, or anything, I cant modify the sound).. it starts to fade about 90mph
how can I test the carrier, or the rearend parts, what is the problem?
I have ENERGY SUSPENSION hyperflex bushing in the rear.
I was exchanged the driveshaft, but the sound was not changed
I changed the tires too, but nothing...
other:
I'm searching the great carrier/gear combo for track/highway use.
I have 3.23 rearend (A4 trany), and I like it, so I dont need new size.
I try to keep my 10bolt rear, because the shipping is very expensive to here.
what is the best for track use? EATON , AUBURN, HEAVY ZEXEL TORSEN?
with which ring&pinion?
my final target hp is 500bhp.
thanks for help
from 1 mph...
other:
thanks for help
ttt.. go up baby..
sorry, I really need help, because I dont know, what is the problem
and no official services at here.
previous changes on rearend:
- all bushing
- all bearings and seal exchanged (pinion, wheel, etc.)
- all wheels, tires
- driveshaft tested, OK, tested with new balanced steel driveshaft
- wheels balanced
- I bought a "new" SLP OEM zexel torsen diff from SLP, carrier exchanged, but it is suspicious.
- I have stock gears 3.23
I try to repair it, for daily driving
thanks for help
- all bushing
- all wheels, tires
- wheels balanced
thanks for help
I recently had extreme noise coming from my rear end...I didn't have any shaking but it started as soon as I rolled forward and in fact did seem to get less noticable at higher speeds (85-90)...It ended up being a reused crush sleeve on my 3.42's causing them to be loose....I Replaced the gears with 4.10's and all is well.....I don't know if we're talking about the same thing, but i thought I would throw it out there..
Originally Posted by Ragtop 99
Are your rear wheels balanced? Rear brakes warped?
my front rotors have lots of small cracks, new rotors are coming,
but I think my rear rotors are good.
I think my problem is similar to this thread:
https://ls1tech.com/forums/gears-axles/265553-please-help-rearend-noise.html
what is the best carrier for the track, if I need to change?
We will burst the rearend in next week
